Yesterday, 10:58 AM
Hi KinCony,
I want to buy the KinCony F16 16-Channel ESP32-S3 Removable Relay Controller for my car (offroad)
https://shop.kincony.com/products/kincon...1712290981
I have watched all the videos by KinCony engineer on YouTube, but I would like direct confirmation from you on the following questions:
- Does the F16 work with DC lights and DC devices? What is the max amps or watts per channel in DC?
- How much current can each channel handle on 12V DC continuously?
- Is there Home Assistant integration, and can I connect the F16 to Home Assistant via WiFi?
- Can the F16 tolerate heat of 60-70°C inside the vehicle?
- The F16 needs 12V DC power. Can I connect it directly to my vehicle's 12V battery, or does it need an external Buck Converter / TVS Diode for protection against car voltage spikes (alternator load dump up to 100V)? If protection is needed, what product do you recommend for vehicle installation?
- Can I connect an external switch to an input so it triggers the relay directly, without waiting for Home Assistant?
- Have any customers used the F16 in cars or vans before?
Thanks,
Yazeed
Thanks,
Yazeed
