"KCS" v3 Modbus RTU over TCP/IP protocol document
KCS protocol webpage, "TCP Server" = "Modbus-RTU-V2". Just RS485 modbus protocol over TCP/IP.
KCSv3 Modbus RTU over TCP Protocol Specification
1. Overview
This document specifies the Modbus RTU over TCP protocol exposed by the
KCSv3 firmware TCP server when the TCP protocol mode is configured for Modbus RTU
frames.
This mode transports a complete Modbus RTU ADU over a TCP socket. It does not use
the standard Modbus TCP MBAP header.
2. Communication Parameters
- Protocol: Modbus RTU ADU transported over TCP
- TCP port: configured by tcp_server_port
- Slave address: configured by tcp_server_protocol_modbus_local_addr
- Register addressing: 0-based Modbus protocol address
- Frame format: [Slave Address][PDU][CRC Lo][CRC Hi]
- CRC: Modbus CRC16, low byte first
- MBAP header: not used
Clients should send one complete RTU ADU frame per TCP request. The firmware
validates the RTU slave address and CRC before processing the PDU.
3. Supported Function Codes
| Function Code | Name                      | Usage                         |
| 0x01          | Read Coils                | Read DO output state          |
| 0x02          | Read Discrete Inputs      | Read DI input state           |
| 0x03          | Read Holding Registers    | Read DAC/IR/RF/energy data    |
| 0x04          | Read Input Registers      | Read ADC/temperature/humidity |
| 0x05          | Write Single Coil         | Set one DO or trigger toggle  |
| 0x06          | Write Single Register     | Set DAC or trigger IR/RF      |
| 0x0F          | Write Multiple Coils      | Set multiple DO channels      |
| 0x10          | Write Multiple Registers  | Set multiple DAC channels     |
4. Addressing Notes
All addresses in this document are 0-based Modbus protocol addresses.
Examples:
- Holding register address 100 is sent as 0x0064 in the Modbus PDU.
- Some Modbus tools display holding register 100 as 40101 or similar. Use the
  tool's 0-based/1-based setting carefully.
5. Coils (Function Codes 0x01, 0x05, 0x0F)
5.1 DO Output State and Control
| Address Range          | Description          | Access                      |
| 0 .. DO_NUM-1          | DO output channels   | 0x01 read, 0x05/0x0F write  |
Write value for function code 0x05:
- 0xFF00: turn ON
- 0x0000: turn OFF
Function code 0x0F supports only the normal DO output range starting at address
0.
5.2 DO Toggle Control
| 0x0100 .. 0x0100+DO_NUM-1   | Toggle DO channels   | 0x05 write only          |
Write 0xFF00 to address 0x0100 + channel_index to toggle that output channel.
Writing 0x0000 is accepted but does not toggle the output.
6. Discrete Inputs (Function Code 0x02)
| 0 .. DI_NUM-1          | DI input channels    | 0x02 read                   |
DI inputs are active-low in the firmware mapping:
- Hardware low / active input returns 1
- Hardware high / inactive input returns 0
7. Holding Registers (Function Codes 0x03, 0x06, 0x10)
7.1 DAC Output Registers
| 0 .. DAC_NUM-1         | DAC output channels  | 0x03 read, 0x06/0x10 write  |
DAC write value range: 0 .. 255.
Function code 0x10 supports only this DAC register range.
7.2 IR/RF Control Registers
| Address  | Name        | Description          | Access                      |
| 0x0040   | IR_SEND     | Send learned IR slot | 0x03 read, 0x06 write       |
| 0x0041   | IR_LEARN    | Learn IR slot/port   | 0x03 read, 0x06 write       |
| 0x0042   | IR_DELETE   | Delete IR slot       | 0x03 read, 0x06 write       |
| 0x0050   | RF_SEND     | Send learned RF slot | 0x03 read, 0x06 write       |
IR_SEND:
- Value: IR memory slot index
- Valid range: 0 .. IR_MEM_NUM-1
IR_LEARN:
- High byte: IR memory slot index
- Low byte: IR send port number, starting from 1
IR_DELETE:
RF_SEND:
- Value: RF memory slot index
- The selected RF slot must exist and be learned
These registers exist only on board variants with the corresponding IR/RF
feature enabled. Otherwise accesses return an illegal data address exception.
7.3 Energy Measurement Registers
Energy data is exposed as read-only Holding Registers and is read with function
code 0x03.
Each energy chip uses 68 holding registers. The base address is:
  base = 100 + chip_index * 100
where chip_index starts from 0.
| Offset Range | Parameter      | Format         | Resolution / Notes       |
| 0 .. 19      | RMS_1..RMS_10  | uint32 CDAB    | Current in A * 1000      |
| 20 .. 39     | WATT_1..WATT_10| int32 CDAB     | Power in W * 10          |
| 40 .. 59     | Energy_1..10   | float32 CDAB   | Energy in kWh            |
| 60 .. 61     | Energy_Sum     | float32 CDAB   | Total energy in kWh      |
| 62           | RMS_V          | uint16         | Voltage in V * 100       |
| 63           | Period         | uint16         | Frequency in Hz * 100    |
| 64 .. 65     | TPS1           | float32 CDAB   | Temperature in deg C     |
| 66 .. 67     | PF             | float32 CDAB   | Power factor             |
Per-channel offsets:
| Channel        | Current Offset | Power Offset   | Energy Offset            |
| 1              | 0              | 20             | 40                       |
| 2              | 2              | 22             | 42                       |
| 3              | 4              | 24             | 44                       |
| 4              | 6              | 26             | 46                       |
| 5              | 8              | 28             | 48                       |
| 6              | 10             | 30             | 50                       |
| 7              | 12             | 32             | 52                       |
| 8              | 14             | 34             | 54                       |
| 9              | 16             | 36             | 56                       |
| 10             | 18             | 38             | 58                       |
For 32-bit integer and float values, read two consecutive registers. The lower
16-bit word is returned first, followed by the upper 16-bit word.
Examples:
- Chip 1 current channel 1: read holding registers 100 and 101
- Chip 2 power channel 1: read holding registers 220 and 221
- Chip 1 voltage: read holding register 162
- Chip 1 frequency: read holding register 163
8. Input Registers (Function Code 0x04)
| Address Range                 | Description          | Format                   |
| 0 .. ADC_NUM-1                | ADC input channels   | uint16 raw ADC value     |
| 0x0100 .. 0x0100+SENSOR_NUM-1 | Temperature sensors  | int16, deg C * 10        |
| 0x0120 .. 0x0120+SENSOR_NUM-1 | Humidity sensors     | int16, %RH * 10          |
If a temperature or humidity sensor is invalid or not present, the returned
value is 0x7FFF.
9. Board-Dependent Limits
The following symbols depend on the compiled board model:
- DO_NUM: number of digital outputs
- DI_NUM: number of digital inputs
- DAC_NUM: number of DAC outputs
- ADC_NUM: number of ADC inputs
- SENSOR_NUM: maximum temperature/humidity sensor slots
- ENERGY_NUM: number of energy measurement chips
N-series energy chip bases:
| Board | ENERGY_NUM | Energy Holding Register Bases        |
| N10   | 1          | 100                                  |
| N20   | 2          | 100, 200                             |
| N30   | 3          | 100, 200, 300                        |
| N60   | 6          | 100, 200, 300, 400, 500, 600         |
10. Exception Codes
| Exception Code | Name                       | Meaning                       |
| 0x01           | Illegal Function           | Unsupported function code     |
| 0x02           | Illegal Data Address       | Unsupported address/range     |
| 0x03           | Illegal Data Value         | Invalid value or quantity     |
| 0x04           | Slave Device Failure       | Runtime failure or overflow   |
11. Request Size Limits
- Read coils/discrete inputs: quantity 1 .. 2000
- Read holding/input registers: quantity 1 .. 125
- Write multiple coils: quantity 1 .. 1968
- Write multiple registers: quantity 1 .. 123
download protocol:
.txt   Modbus_RTU_over_TCP_Protocol.txt (Size: 11.05 KB / Downloads: 63)
