How to enable 2 IIC buses at the same time?
Dear Sir,
May I know how to enable both IIC buses for DI and DO at the same time for KC868-A128 in Arduino IDE?
I can only enable one each time, so that I cannot program the board to trigger outputs when inputs changed.
Thanks,
Ron
here is arduino code INPUT trigger OUTPUT for KC868-A128
  KC868-A128
  DI1 -> DO1
  DI2 -> DO2
  DI128 -> DO128
  IIC Bus-A for relay DO:
  SDA = GPIO5
  SCL = GPIO16
  IIC Bus-B for DI:
  SDA = GPIO15
  SCL = GPIO4
#include <Arduino.h>
#include <Wire.h>
#define DO_SDA 5
#define DO_SCL 16
#define DI_SDA 15
#define DI_SCL 4
// PCF8575 address order
uint8_t pcfAddr[8] = {
  0x24, 0x25, 0x21, 0x22,
  0x26, 0x27, 0x20, 0x23
// relay output state
// PCF8575: 1 = OFF, 0 = ON
uint16_t relayState[8];
uint16_t readPCF8575(TwoWire &wireBus, uint8_t addr) {
  wireBus.requestFrom(addr, (uint8_t)2);
  if (wireBus.available() < 2) {
    return 0xFFFF;
  uint8_t lowByte = wireBus.read();
  uint8_t highByte = wireBus.read();
  return ((uint16_t)highByte << 8) | lowByte;
void writePCF8575(TwoWire &wireBus, uint8_t addr, uint16_t value) {
  wireBus.beginTransmission(addr);
  wireBus.write(value & 0xFF);
  wireBus.write((value >> 8) & 0xFF);
  wireBus.endTransmission();
  delay(1000);
  Wire.begin(DO_SDA, DO_SCL);      // IIC Bus-A, relay
  Wire1.begin(DI_SDA, DI_SCL);     // IIC Bus-B, digital input
  // Init all relays OFF
  for (int i = 0; i < 8; i++) {
    relayState[i] = 0xFFFF;
    writePCF8575(Wire, pcfAddr[i], relayState[i]);
  Serial.println("KC868-A128 DI trigger DO ready.");
  for (int board = 0; board < 8; board++) {
    uint16_t inputState = readPCF8575(Wire1, pcfAddr[board]);
    // DI low active
    // DI = 0 -> relay ON
    // DI = 1 -> relay OFF
    relayState[board] = inputState;
    writePCF8575(Wire, pcfAddr[board], relayState[board]);
  delay(50);
arduino code:
.zip   input-trigger-output.zip (Size: 932 bytes / Downloads: 40)
BIN file, download to ESP32 by 0x0 address, directly to use:
.zip   input-trigger-output.ino.merged.zip (Size: 183.82 KB / Downloads: 46)
