06-11-2026, 08:42 PM
Example for different sending methods
https://github.com/sui77/rc-switch/
#include <RCSwitch.h>
Serial.begin(9600);
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(digitalPinToInterrupt(2));
delay(500);
mySwitch.send(5396, 24);
// Optional set protocol (default is 1, will work for most outlets)
// mySwitch.setProtocol(2);
// Optional set pulse length.
// mySwitch.setPulseLength(320);
// Optional set number of transmission repetitions.
mySwitch.setRepeatTransmit(15);
/* See Example: TypeA_WithDIPSwitches */
mySwitch.switchOn("11111", "00010");
delay(1000);
mySwitch.switchOff("11111", "00010");
delay(1000);
/* Same switch as above, but using decimal code */
mySwitch.send(5393, 24);
delay(1000);
delay(1000);
/* Same switch as above, but using binary code */
mySwitch.send("000000000001010100010001");
delay(1000);
mySwitch.send("000000000001010100010100");
delay(1000);
/* Same switch as above, but tri-state code */
mySwitch.sendTriState("00000FFF0F0F");
delay(1000);
mySwitch.sendTriState("00000FFF0FF0");
delay(1000);
// delay(20000);
433-send.zip (Size: 685 bytes / Downloads: 62)
433-send.ino.merged.zip (Size: 186.47 KB / Downloads: 59)
