06-15-2026, 06:16 AM
KC868-A8S read KinCony TS modbus sensor by RS485. USB print the temperature and humidity value.
arduino source code download:
rs485-sensor.zip (Size: 1.02 KB / Downloads: 51)
ESP32 BIN file download (just download to ESP32 module begin 0x0 address):
rs485-sensor.ino.merged.zip (Size: 169.79 KB / Downloads: 51)
Made by KinCony IoT
https://www.kincony.com
#include <HardwareSerial.h>
#define RS485_RX 32
#define RS485_TX 33
HardwareSerial RS485Serial(2);
// Read input register: ID=1, Function=04, Start=0000, Quantity=0002
uint8_t readCmd[] = {
0x01, 0x04, 0x00, 0x00,
0x00, 0x02, 0x71, 0xCB
uint16_t modbusCRC(uint8_t *buf, int len)
uint16_t crc = 0xFFFF;
for (int pos = 0; pos < len; pos++) {
crc ^= buf[pos];
for (int i = 0; i < 8; i++) {
if (crc & 0x0001) {
crc >>= 1;
crc ^= 0xA001;
} else {
crc >>= 1;
return crc;
float decodeTemperature(uint16_t value)
if (value >= 10000) {
return -1.0 * (value - 10000) * 0.1;
} else {
return value * 0.1;
void setup()
RS485Serial.begin(
9600,
SERIAL_8N1,
RS485_RX,
RS485_TX
delay(1000);
Serial.println();
Serial.println("RS485 Modbus Temperature & Humidity Sensor");
void loop()
while (RS485Serial.available()) {
RS485Serial.read(); // clear old data
RS485Serial.write(readCmd, sizeof(readCmd));
RS485Serial.flush();
delay(200);
uint8_t buf[32];
int len = 0;
buf[len++] = RS485Serial.read();
if (len >= sizeof(buf)) break;
if (len == 9) {
Serial.print("RX: ");
for (int i = 0; i < len; i++) {
if (buf[i] < 0x10) Serial.print("0");
Serial.print(buf[i], HEX);
Serial.print(" ");
Serial.println();
uint16_t crc_recv = buf[7] | (buf[8] << 8);
uint16_t crc_calc = modbusCRC(buf, 7);
if (crc_recv == crc_calc) {
uint16_t temp_raw = (buf[3] << 8) | buf[4];
uint16_t hum_raw = (buf[5] << 8) | buf[6];
float temperature = decodeTemperature(temp_raw);
float humidity = hum_raw * 0.1;
Serial.print("Temperature: ");
Serial.print(temperature, 1);
Serial.print(" C ");
Serial.print("Humidity: ");
Serial.print(humidity, 1);
Serial.println(" %RH");
} else {
Serial.println("CRC Error");
} else {
Serial.print("Response length error, len=");
Serial.println(len);
delay(1000);
