Threads: 1
Good afternoon! I bought two KC868 A8 and KC868 A16 boards to use with Home Assistant. I found configuration files for these boards on a forum, and all the inputs/outputs work, but I can't connect the sensors. Help please.
Threads: 1
Good afternoon! But I'm using a board with Home Assistant. If I install the KCS firmware, will I be able to control the KC868 board using Home Assistant?
Threads: 1,490
sure. there are two way use for home assistant.
1: download KCS firmware, integrate to home assistant by MQTT.
2: config by ESPHome.
Threads: 1
07-17-2026, 08:07 AM
(This post was last modified: 07-17-2026, 08:52 AM by Наиль.)
I would like the second option.
Please write a configuration file fragment for the KC868 A8 board to connect multiple DS18B20 sensors to a single input using the 1-Wire Bus
Threads: 1
I don't know how to find out the address of the sensor. "address: 0x1234567812345628".
Here's my configuration file, which passed the check, but it doesn't show the temperature.
- platform: dallas_temp
one_wire_id: bus_S1
name: "S1 Temperature"
update_interval: 10s
one_wire_id: bus_S2
name: "S2 Temperature"
one_wire:
pin: GPIO14
pin: GPIO13
