07-25-2026, 06:25 AM
friendly_name: b2
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
external_components:
- source:
type: git
ref: v1.3.1
# hardware_uart: USB_SERIAL_JTAG
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 38
rx_pin: 39
- id: tuya_mcu_uart
tx_pin: GPIO14
rx_pin: GPIO13
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: qk4eefxayleh2x5s
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
- platform: uart
uart_id: uart_1
pin: 4
inverted: false
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "b2_output01"
pin: 46
inverted: false
dp_id: 2
internal: true
bind_switch_id: "b2_output02"
number: 6
dp_id: 111
bind_binary_sensor_id: b2_input01
internal: true
number: 7
dp_id: 112
bind_binary_sensor_id: b2_input02
internal: true
##pull-up resistance on PCB
number: 47
number: 48
number: 17
number: 40
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony B2");
B2-HA-Tuya.txt (Size: 3.58 KB / Downloads: 12)
