[arduino code examples for B2]-01 Turn ON/OFF OUTPUT
   Made by KinCony IoT
   https://www.kincony.com
   Demo: KinCony B2 Relay Control
#define RELAY1_PIN 4
#define RELAY2_PIN 46
// Relay logic (Active LOW)
#define RELAY_ON  LOW
#define RELAY_OFF HIGH
void setup()
  pinMode(RELAY1_PIN, OUTPUT);
  pinMode(RELAY2_PIN, OUTPUT);
  // Turn OFF both relays at startup
  digitalWrite(RELAY1_PIN, RELAY_OFF);
  digitalWrite(RELAY2_PIN, RELAY_OFF);
void loop()
  digitalWrite(RELAY1_PIN, RELAY_ON);
  delay(1000);
  delay(1000);
  digitalWrite(RELAY2_PIN, RELAY_ON);
  delay(1000);
  Serial.println("Relay 2 OFF");
  delay(1000);
  delay(1000);
  delay(1000);
.zip   1-relay.zip (Size: 450 bytes / Downloads: 17)
.zip   1-relay.ino.merged.zip (Size: 179.96 KB / Downloads: 18)
