07-25-2026, 06:29 AM
Made by KinCony IoT
https://www.kincony.com
Demo: KinCony B2 Digital Input Read
Board: KinCony B2 (ESP32)
Digital Input 1 -> GPIO6
Digital Input 2 -> GPIO7
#define DI1_PIN 6
#define DI2_PIN 7
// Store previous input states
int lastDI1State = HIGH;
int lastDI2State = HIGH;
void setup()
// Initialize serial monitor
Serial.println("KinCony B2 Digital Input Demo");
// Configure digital input pins
// Change INPUT to INPUT_PULLUP if your hardware requires internal pull-up
pinMode(DI1_PIN, INPUT_PULLUP);
pinMode(DI2_PIN, INPUT_PULLUP);
// Read initial states
lastDI1State = digitalRead(DI1_PIN);
lastDI2State = digitalRead(DI2_PIN);
Serial.print("DI1 Initial State: ");
Serial.println(lastDI1State);
Serial.print("DI2 Initial State: ");
Serial.println(lastDI2State);
void loop()
// Read current input states
int di1State = digitalRead(DI1_PIN);
int di2State = digitalRead(DI2_PIN);
// Check if DI1 state changed
if (di1State != lastDI1State)
lastDI1State = di1State;
Serial.print("DI1 Changed: ");
Serial.println(di1State);
// Check if DI2 state changed
if (di2State != lastDI2State)
lastDI2State = di2State;
Serial.print("DI2 Changed: ");
Serial.println(di2State);
// Small delay for stability
delay(10);
2-digital-input.zip (Size: 697 bytes / Downloads: 7)
2-digital-input.ino.merged.zip (Size: 180.26 KB / Downloads: 11)
