KinCony F8 + ESPHome: Unable to Enter Tuya Pairing Mode (Smart Config)
Hi!
I'm trying to pair a KinCony F8 device with my Tuya account. I flashed it with an ESPHome firmware, and it is working perfectly with Home Assistant.
Now I'd like to add Tuya connectivity. Based on the example code shared in this forum, I installed the firmware on my device, but I can't get it to enter pairing mode.
One thing that seems unusual is that the Tuya module never appears to complete its initialization. As shown in the attached ESPHome logs, the message "begin smart config" is printed repeatedly about every 50 ms, making it look as if the module is continuously trying to enter Smart Config instead of staying in pairing mode. Could this indicate that the Tuya module is not responding correctly or that I'm missing an initialization step?
I've attached the ESPHome firmware and the ESPHome logs.
I would really appreciate your help identifying what I'm doing wrong and how to get it working.
Thank you very much!
Guillermo
.txt   test-logs.txt (Size: 6.34 KB / Downloads: 12)
.txt   Kincony-F8-ESPHome-Tuya.txt (Size: 4.14 KB / Downloads: 10)
Monday we will test it ,feedback to you.
you can use F8 ESPHome yaml for Tuya by this link: https://www.kincony.com/forum/showthread.php?tid=9714
