SSD1306 with case
Is there a template to cut a hole in the A16v3 case to be able to show the contents of the SSD1306 screen? Or do you have a see-through case to be able to make the screen visible?
Currently, it doesn't make sense to add a screen under the cover, since you have to undo four screws to be able to see it.
Thanks in advance!
-hans-martijn
if you want use SSD1306, we suggest chose B16M controller.
Why? The screens work perfectly well, it's just the case which is difficult. I have four A16v3's, so I would have to buy four new devices (twice as expensive, with tuya (which I don't want)), just for the case?
sorry, now no plastic shell with windows for SSD1306
