08-31-2026, 12:00 AM
* KinCony 16-Channel Analog Input Monitor
* Four ADS1115 ADC modules are used:
* ADS1115-1 (U35): CH1-CH4 I2C address: 0x48
* ADS1115-2 (U7): CH5-CH8 I2C address: 0x49
* ADS1115-3 (U15): CH9-CH12 I2C address: 0x4B
* ADS1115-4 (U19): CH13-CH16 I2C address: 0x4A
* ESPHome equivalent configuration:
* gain: 4.096
* filters:
* - lambda: 'return x <= 0.0025f ? 0.0f : x;'
* - multiply: 5.16696
* - clamp:
* min_value: 0.0
* max_value: 10.0
* Only channels with an input voltage greater than 0.5V
* will be printed.
* Copyright: Made by KinCony IoT: https://www.kincony.com
#include <Wire.h>
#include <DFRobot_ADS1115.h>
// I2C pins
#define SDA_PIN 8
#define SCL_PIN 18
// ADS1115 I2C addresses
#define ADS1115_1_ADDR 0x48
#define ADS1115_2_ADDR 0x49
#define ADS1115_3_ADDR 0x4B
#define ADS1115_4_ADDR 0x4A
// ESPHome calibration multiplier
#define VOLTAGE_MULTIPLIER 5.16696f
// ESPHome zero threshold
#define ADC_ZERO_THRESHOLD 0.0025f
// Print threshold
#define PRINT_THRESHOLD 0.5f
// Maximum input voltage
#define MAX_INPUT_VOLTAGE 10.0f
// Create ADS1115 objects
DFRobot_ADS1115 ads1(&Wire);
DFRobot_ADS1115 ads2(&Wire);
DFRobot_ADS1115 ads3(&Wire);
DFRobot_ADS1115 ads4(&Wire);
* Read ADS1115 channel and convert to actual input voltage.
* DFRobot readVoltage() returns voltage in mV.
* ESPHome:
* x <= 0.0025V -> 0V
* x * 5.16696
* clamp 0~10V
float readInputVoltage(DFRobot_ADS1115 &ads, uint8_t channel)
// Read ADC voltage in mV
uint16_t adc_mV = ads.readVoltage(channel);
// Convert mV to V
float adcVoltage = adc_mV / 1000.0f;
// ESPHome lambda filter
if (adcVoltage <= ADC_ZERO_THRESHOLD)
return 0.0f;
// ESPHome multiply filter
float inputVoltage = adcVoltage * VOLTAGE_MULTIPLIER;
// ESPHome clamp filter
if (inputVoltage < 0.0f)
inputVoltage = 0.0f;
if (inputVoltage > MAX_INPUT_VOLTAGE)
inputVoltage = MAX_INPUT_VOLTAGE;
return inputVoltage;
* Check one analog channel.
* If the actual input voltage is greater than 0.5V,
* print the channel number and voltage.
void checkChannel(
uint8_t adcChannel,
uint8_t channelNumber)
float voltage = readInputVoltage(ads, adcChannel);
if (voltage > PRINT_THRESHOLD)
Serial.print("CH");
Serial.print(channelNumber);
Serial.print(": ");
Serial.print(voltage, 2);
Serial.println(" V");
void setup(void)
// Initialize I2C
Wire.begin(SDA_PIN, SCL_PIN);
* ADS1115 gain = 4.096V
* This corresponds to ESPHome:
* gain: 4.096
* DFRobot library:
* eGAIN_ONE = 4.096V
// ADS1115-1
ads1.setAddr_ADS1115(ADS1115_1_ADDR);
ads1.setGain(eGAIN_ONE);
ads1.setMode(eMODE_SINGLE);
ads1.setRate(eRATE_128);
ads1.setOSMode(eOSMODE_SINGLE);
ads1.init();
// ADS1115-2
ads2.setAddr_ADS1115(ADS1115_2_ADDR);
ads2.setGain(eGAIN_ONE);
ads2.setMode(eMODE_SINGLE);
ads2.setRate(eRATE_128);
ads2.setOSMode(eOSMODE_SINGLE);
ads2.init();
// ADS1115-3
ads3.setAddr_ADS1115(ADS1115_3_ADDR);
ads3.setGain(eGAIN_ONE);
ads3.setMode(eMODE_SINGLE);
ads3.setRate(eRATE_128);
ads3.setOSMode(eOSMODE_SINGLE);
ads3.init();
// ADS1115-4
ads4.setAddr_ADS1115(ADS1115_4_ADDR);
ads4.setGain(eGAIN_ONE);
ads4.setMode(eMODE_SINGLE);
ads4.setRate(eRATE_128);
ads4.setOSMode(eOSMODE_SINGLE);
ads4.init();
Serial.println();
Serial.println("KinCony 16-Channel Analog Input Test");
Serial.println("--------------------------------------");
Serial.println("ADS1115 Gain: 4.096V");
Serial.println("Multiplier: 5.16696");
Serial.println("Print threshold: 0.50V");
Serial.println();
void loop(void)
// ADS1115-1: CH1 ~ CH4
if (ads1.checkADS1115())
checkChannel(ads1, 0, 1);
checkChannel(ads1, 1, 2);
checkChannel(ads1, 2, 3);
checkChannel(ads1, 3, 4);
else
Serial.println("ADS1115-1 (0x48) Disconnected!");
// ADS1115-2: CH5 ~ CH8
if (ads2.checkADS1115())
checkChannel(ads2, 0, 5);
checkChannel(ads2, 1, 6);
checkChannel(ads2, 2, 7);
checkChannel(ads2, 3, 8);
else
Serial.println("ADS1115-2 (0x49) Disconnected!");
// ADS1115-3: CH9 ~ CH12
if (ads3.checkADS1115())
checkChannel(ads3, 0, 9);
checkChannel(ads3, 1, 10);
checkChannel(ads3, 2, 11);
checkChannel(ads3, 3, 12);
else
Serial.println("ADS1115-3 (0x4B) Disconnected!");
// ADS1115-4: CH13 ~ CH16
if (ads4.checkADS1115())
checkChannel(ads4, 0, 13);
checkChannel(ads4, 1, 14);
checkChannel(ads4, 2, 15);
checkChannel(ads4, 3, 16);
else
Serial.println("ADS1115-4 (0x4A) Disconnected!");
// Scan every 1 second
delay(1000);
3-ads1115_adc.zip (Size: 1.68 KB / Downloads: 25)
3-ads1115_adc.ino.merged.zip (Size: 195.04 KB / Downloads: 28)
