Threads: 6
Hey,
I've got a kinkony a16 board running esphome connected through ethernet cable to homeassistant.
[*]Installation method Home Assistant OS:
[*]Core 2025.9.4
[*]Supervisor 2026.09.3
[*]Operating System 16.2
[*]ESPHome Device Builder:
Current version: 2025.9.2
[*]Everything works as expected but I need to update. I've updated esphome to 2026.9.1 without updating homeassistant and all the switches gone offline. I've done a restart then I just restored the previous system and all works again.
[*]Does the board require some special settings for esphome 2026.9.1 ?
Thanks!
Threads: 6
friendly_name: Surgery
esp32:
board: esp32dev
framework:
type: esp-idf
encryption:
key: "xxxx"
ota:
- platform: esphome
password: "2xxxxx"
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
clk:
mode: CLK_OUT
pin: GPIO17
uart:
- id: rs485
tx_pin: GPIO13
rx_pin: GPIO16
baud_rate: 9600
remote_receiver:
number: GPIO2
ignore_strapping_warning: true
remote_transmitter:
number: GPIO15
carrier_duty_percent: 100%
sda: GPIO4
scl:
number: GPIO5
pcf8574:
- id: inputs_1_8
address: 0x22
pcf8575: false
- id: inputs_9_16
address: 0x21
pcf8575: false
- id: outputs_1_8
address: 0x24
pcf8575: false
- id: outputs_9_16
address: 0x25
pcf8575: false
number: GPIO32
number: GPIO33
number: GPIO14
pcf8574: inputs_1_8
mode: INPUT
on_press:
then:
- switch.turn_on: out_y01
on_release:
then:
- switch.turn_off: out_y01
pcf8574: inputs_1_8
number: 1
mode: INPUT
on_press:
then:
- switch.turn_on: out_y02
on_release:
then:
- switch.turn_off: out_y02
pcf8574: inputs_1_8
number: 2
mode: INPUT
on_press:
then:
- switch.turn_on: out_y03
on_release:
then:
- switch.turn_off: out_y03
pcf8574: inputs_1_8
number: 3
mode: INPUT
on_press:
then:
- switch.turn_on: out_y04
on_release:
then:
- switch.turn_off: out_y04
pcf8574: inputs_1_8
number: 4
mode: INPUT
on_press:
then:
- switch.turn_on: out_y05
on_release:
then:
- switch.turn_off: out_y05
pcf8574: inputs_1_8
number: 5
mode: INPUT
on_press:
then:
- switch.turn_on: out_y06
on_release:
then:
- switch.turn_off: out_y06
pcf8574: inputs_1_8
number: 6
mode: INPUT
on_press:
then:
- switch.turn_on: out_y07
on_release:
then:
- switch.turn_off: out_y07
pcf8574: inputs_1_8
number: 7
mode: INPUT
on_press:
then:
- switch.turn_on: out_y08
on_release:
then:
- switch.turn_off: out_y08
pcf8574: inputs_9_16
mode: INPUT
on_press:
then:
- switch.turn_on: out_y09
on_release:
then:
- switch.turn_off: out_y09
number: 1
mode: INPUT
on_press:
then:
- switch.turn_on: out_y10
on_release:
then:
- switch.turn_off: out_y10
number: 2
mode: INPUT
on_press:
then:
- switch.turn_on: out_y11
on_release:
then:
- switch.turn_off: out_y11
number: 3
mode: INPUT
on_press:
then:
- switch.turn_on: out_y12
on_release:
then:
- switch.turn_off: out_y12
number: 4
mode: INPUT
on_press:
then:
- switch.turn_on: out_y13
on_release:
then:
- switch.turn_off: out_y13
number: 5
mode: INPUT
on_press:
then:
- switch.turn_on: out_y14
on_release:
then:
- switch.turn_off: out_y14
number: 6
mode: INPUT
on_press:
then:
- switch.turn_on: out_y15
on_release:
then:
- switch.turn_off: out_y15
number: 7
mode: INPUT
on_press:
then:
- switch.turn_on: out_y16
on_release:
then:
- switch.turn_off: out_y16
pcf8574: outputs_1_8
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
on_turn_on:
then:
- delay: 3s
number: 6
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 7
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
pcf8574: outputs_9_16
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 4
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
number: 7
mode: OUTPUT
on_turn_on:
then:
- delay: 6s
Threads: 1,560
upload yaml file, so that i can directly to test.
Threads: 6
I'd like to add to my first comment that not everything works as expected now.
After restoring esphome to 2025.9.2 the switches came back online but after restarting home assistant the switches became unavailable. The board itself is online in esphome but the switches can't be used in home assistant.
I've added the yaml file but .yaml extension is not allowed.
Thanks!
surgery-before-update.txt (Size: 8.9 KB / Downloads: 1)
