SSD not visible for install home assistant in pi imager
install home assistant on PI5R16 , following the steps , in pi imager i can't see my SSD ( it's new and it is 256GB ) , any idea ? smal sd card is possible this is fine
change SD card, some SD cards have compatibility issues.
home assistant is running , but from a small 32gb sd ( not future proof ) , ssd 240gb transcend is still it it , but it's not found ?
(Yesterday, 08:42 AM)admin Wrote: change SD card, some SD cards have compatibility issues.
i want to use SSD safer , faster , better option . i have new one but the pi5 don't see the ssd ,
this is the one that i use Transcend 240GB SATA III 6Gb/s MTS420S 42mm M.2 SSD 420S Solid State Drive  , but it is NOT found by server . or is this kingspec  NXM-2242, 3500MB/s better ?
Pi5 server board can install SSD disk, just need open black box.
Black box is open , ssd disk is install in the slot . But can´t see disk in pi imager . I did the steps as on the tutorial , but no disk to select
make sure RED switch bit4=ON.
https://www.kincony.com/forum/showthread.php?tid=9824
Bit4=on ,
how about insert SD card or another SSD?
Sd works , i can install home assistant.  Still no ssd visibleb.
Unfortunately i don´t have other ssd to test ? . This is new one .
if you want, we can send you a new top black PCB (CM5 core board), you can replace the pcb install your SSD again for testing.
