[arduino code examples for MT4v2]-01 Control 4 channel DC motor
* KinCony MT4V2 DC Motor Test
* Power ON -> M1-M4 run at 100%
* Made by KinCony IoT
* https://www.kincony.com
#include <Arduino.h>
#define RXD 15
#define TXD 16
HardwareSerial MotorSerial(1);
uint16_t crc16(const uint8_t *data, uint8_t len)
  uint16_t crc = 0xFFFF;
  while (len--)
    crc ^= *data++;
    for (uint8_t i = 0; i < 8; i++)
      crc = (crc & 1) ? (crc >> 1) ^ 0xA001 : crc >> 1;
  return crc;
void sendFrame(uint8_t *data)
  uint16_t crc = crc16(data, 6);
  MotorSerial.write(data, 6);
  MotorSerial.write(crc & 0xFF);
  MotorSerial.write(crc >> 8);
  MotorSerial.flush();
  delay(50);
  // Clear ARM response
  while (MotorSerial.available())
    MotorSerial.read();
void enableMotor()
  uint8_t cmd[] = {
    1, 0x05,
    0x01, 0xF7,     // Coil 503
    0xFF, 0x00      // ON
  sendFrame(cmd);
void setMotor(uint8_t motor, int16_t speed)
  uint16_t reg = 2000 + motor - 1;
  uint8_t cmd[] = {
    1, 0x06,
    uint8_t(reg >> 8),
    uint8_t(reg),
    uint8_t(speed >> 8),
    uint8_t(speed)
  sendFrame(cmd);
void startMotors()
  enableMotor();
  setMotor(1, 100);  //100 is speed
  setMotor(2, 100);  //100 is speed
  setMotor(3, 100);  //100 is speed
  setMotor(4, 100);  //100 is speed
void setup()
  MotorSerial.begin(115200, SERIAL_8N1, RXD, TXD);
  // Wait for ARM CPU startup
  delay(3000);
  startMotors();
void loop()
  // Refresh commands every 2 seconds
  delay(2000);
  startMotors();
.zip   1-motor.zip (Size: 797 bytes / Downloads: 4)
.zip   1-motor.ino.merged.zip (Size: 185.77 KB / Downloads: 4)
