[arduino code examples for MT4v2]-11 IR receiver decode
* SimpleReceiver.cpp
* Demonstrates receiving ONLY NEC protocol IR codes with IRremote
* If no protocol is defined, all protocols (except Bang&Olufsen) are active.
*  This file is part of Arduino-IRremote https://github.com/Arduino-IRremote/Arduino-IRremote.
* MIT License
* Copyright (c) 2020-2025 Armin Joachimsmeyer
* Permission is hereby granted, free of charge, to any person obtaining a copy
* of this software and associated documentation files (the "Software"), to deal
* in the Software without restriction, including without limitation the rights
* to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
* copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
* INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
* CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
* OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <Arduino.h>
#include <IRremote.hpp> // include the library
uint8_t sender_pins[] = {47, 48};
uint8_t receiver_pin = 13;
int sender_pin_num = sizeof(sender_pins) / sizeof(sender_pins[0]);
uint8_t sender_pin_idx = 0;
uint8_t receive_cnt = 0;
uint8_t sCommand = 0x34;
uint8_t sRepeats = 0;
    IrReceiver.begin(receiver_pin, false);
    IrSender.begin(sender_pins[0]);
    xTaskCreate(
      sendIr,    // Function that should be called
      "Send IR",   // Name of the task (for debugging)
      4096,            // Stack size (bytes)
      NULL,            // Parameter to pass
      1,               // Task priority
      NULL             // Task handle
void sendIr(void * parameter) {
  delay(2000);
  IrSender.setSendPin(47);
  IrSender.sendNEC(0x00, sCommand, sRepeats);
  Serial.printf("send by pin: %d\n", 47);
  delay(2000);
  IrSender.setSendPin(48);
  Serial.printf("send by pin: %d\n", 48);
  delay(2000);
  vTaskDelete(NULL);
  if (IrReceiver.decode()) {
      Serial.println("recv data");
      if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
          Serial.println(F("Received noise or an unknown (or not yet enabled) protocol"));
          // We have an unknown protocol here, print extended info
          IrReceiver.printIRResultRawFormatted(&Serial, true);
          IrReceiver.resume(); // Do it here, to preserve raw data for printing with printIRResultRawFormatted()
      } else {
          IrReceiver.resume(); // Early enable receiving of the next IR frame
          IrReceiver.printIRResultShort(&Serial);
          IrReceiver.printIRSendUsage(&Serial);
  } else {
    // Serial.println("no data");
.zip   11-IR-receiver.zip (Size: 1.61 KB / Downloads: 6)
.zip   11-IR-receiver.ino.merged.zip (Size: 194.06 KB / Downloads: 6)
