Which KinCony board for a 12 V locking toolbox with Home Assistant, Wi-Fi and
Hello KinCony team,
I’m building a large steel mechanics’ toolbox for my workshop in Leeds, UK. It has an electric lock, and I’d like one KinCony board to be its controller. I looked at your product selector but I’m not sure which board fits, so here’s what the system needs to do.
What the box does
A small 12 V DC motor (a linear actuator) moves a bar that locks and unlocks all the drawers. It changes direction when you reverse its power (+/−). It has its own end-stop switches, so it stops by itself at each end. It draws less than 1 A.
A wireless key fob unlocks and locks the box. The fob receiver gives a simple relay contact (on/off).
A chain of 7 small switches tells us whether every drawer is fully closed and caught. It gives one contact: closed = all locked.
A green LED on the outside shows “locked”.
There’s also a normal mechanical key, so the electronics never have to be perfect.
What I want the KinCony board to do
Run with Home Assistant (on the board itself, or connected to Home Assistant on my network).
Wi-Fi to connect to my network. The board sits inside a closed steel box, so an external antenna connector matters.
Bluetooth, so the box can tell when my phone is close by (auto-lock when I walk away).
Drive the 12 V motor in both directions (lock and unlock), using relays or a motor driver output.
Read at least 2 inputs: the fob receiver contact and the “all drawers locked” contact.
Run from 12 V DC and use as little power as possible when idle. When mains power is off, the box runs on a Milwaukee M18 battery, so idle power decides how long the battery lasts.
Stay safe at power-up: after a power cut, the board must not unlock the box when power comes back.
Power side (only if you have something suitable)
The box has mains power plus a battery backup. At the moment I plan to use Mean Well parts to switch automatically between the mains 12 V supply and the battery 12 V. If KinCony makes a dual-power / automatic changeover module or a 12 V UPS-type module, please tell me.
Space
The electronics sit in a hidden compartment about 97 mm high. The board can lie flat or go on a DIN rail.
My questions
Which KinCony board do you recommend for this? I’ve looked at the MT4 and the Pi-based boards (Pi5R8, Server-Mini). Are those right, or is there a better fit?
Does that board have Wi-Fi, Bluetooth and an external antenna option?
Can it reverse a 12 V DC motor, or do I need an extra module?
What’s its idle power at 12 V?
What do its relays do at power-up (all off)?
Do you have a dual-power changeover or 12 V backup module?
Price and shipping to the UK, please.
I can share drawings and a 3D model if that helps. Thank you!
you can chose ESP32 mosfet board or raspberry pi5 mosfet board. it's up to you. mosfet output can drive 12v lock directly.
Thank you, that helps. The ESP32 MOSFET board (B8M) looks like the right fit for me. A few quick questions about it:
1. It uses the ESP32-S3-WROOM-1U. Does it come with an external antenna, or which antenna and cable should I buy?
2. What's its idle current at 12 V with Wi-Fi on?
3. At power-up, are all MOSFET outputs OFF until the firmware turns them on?
4. My lock is a reversing motor, not a solenoid, so I'll use one MOSFET output to switch a 12 V reversing relay. Is a MOSFET output fine for a relay coil, and does the board have flyback protection on its outputs?
5. The B8M shows sold out. When will it be back in stock, and what's the price with shipping to Leeds, UK?
6. Do you have a module that switches automatically between mains 12 V and battery 12 V?
Thanks again,
K
1. B8M already have wifi antenna SMA socket on the box. Also will include wifi antenna.
2. suggest you test by yourself, about 100mA.
3. it can set by KCS v3 firmware, when power on , mosfet output=OFF or before power off state.
4. mosfet can drive relay's coin directly, yes, have flyback protection component on pcb.
5. where you seen it sold out? it's in stock, here is order link: https://shop.kincony.com/products/esp32-...8ch-mosfet
6. sorry, we don't have this type product.
