Products Parameter:
Dimension: 108x117x40mm
Working Voltage: DC 12V
Working Temp: -20℃~70℃
Output Load:each 250V/10A
Input port qty:8 ports
Output port qty:16 ports
The following information introduces KC868-H8 controller. KC868-H4, KC868-H2, KC868-H8, KC868-H32 Smart Home Automation controller are KC868 series of KinCony’s products, so phone APP and PC software are compatible. There are only different input and output channel.
Packaging:
Products Function:
2. Remote controlling the opening/closing of 16 routes or 16 groups’ circuits.
3. Supporting secondary development
4. Supporting APP remote controlling
5. Widely used for lights controlling of kinds of occasion (like Indoor, theater or Amusement Park etc) and switching of mechanical equipments, and management of the computers in the cyber bar and so on.
Products Features:
2. each route is equal an independent switch.
This is PC software for KC868-H16, It can control by LAN (local control) or WAN (remote control)
new software support CCTV (only use for KinCony’s ipcamera product). When you see the video control the relay switch.
This is config menu, The title and copyright and all relays’ name can be changed by yourself.
If you connect with “KC868 Voice Assistant” module, controller can control voice control by Amazon Alexa or Google Home Speaker or Amazon Alexa or Google Home phone APP.
For Development Communication Protocol
We supply complete source program Toolkit of VS2005(Microsoft Visual Studio 2005) , and we give the controlling examples through RS232 serial port and Ethernet socket,to help customers carrying on the secondary development.
The computer software can control the relay switch, and also show the input state.Details showed from below screenshots.
We can supply the DEMO code of C++Builder, Delphi, VB.Net, Python and iOS versoins.
Knowledge Base
Disk Downloads
Disk for KC868-H16 Controller (APP, PC software, VirCom tool)
Sample Code
Videos
