KinCony A32 Pro ESP32 relay board based on ESP32-S3-WROOM-1U (N16R8) wifi chip, it have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. Support 32 channel relay output and 2 channel dc 0-10v dimmer output, 2 channel 1-wire GPIOs, 4 channel analog input ports. It support 4G module (SIM7600 series) for SMS, voice call, GPRS communication for Tuya mobile application. SIM7600 module also support GPS, just need connect IPEX extender GPS antena. Download KCS firmware , use SMS or call to turn ON/OFF relay will be very easy for home automation DIY. LCD display will show wifi and ethernet IP address and 4G connection state and Tuya connection state. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware (Note: tasmota support INPUT + OUTPUT total 32 channel) for smart home automation DIY.
Model No. KinCony A32 Pro
Description: KinCony 32 Channel ESP32-S3 Relay Controller – A32 Pro
Power supply: 12V DC
PCB Size: 250mm*122mm
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB,SIM7600 Series 4G Module(optional),LCD,RF433MHz Receiver
Outputs:
32CH Relay Outputs, every channel have “COM,NO”:250VAC 7A
2CH 0-10v dc
Inputs:
Inputs 2 analog input DC 0-5V (AI1,AI2)
2 analog input 4-20mA (AI3,AI4)
40 channel dry contact inputs
32 manual control buttons
3 buttons: S1:ESP32 Reset S2:ESP32 Download S3: Tuya module Reset
1-Wire GPIO: 2CH
