We improved ethernet relay module — KC868-H32. The new model called “KC868-H32L”. What’s the difference between “KC868-H32” and “KC868-H32L”?
1: Relay Max load from 5A to 10A.
2:Use pluggable terminals,easy to install and maintain.
3:The function of power-off memory of relay switch is added. If the power is cut off suddenly or power failure, the relay will automatically return to the state before the power cut when the power is called again.
Product Display
Product Description
Dimension: 206*117*40mm
Material: Fire resistance ABS、metal shell
Relay Remember: Power ON Auto recovery
Working Voltage: DC 12V
Working Temp: -20℃ ~70℃
Output Load: each 250V/10A
Communication Mode: Ethernet/ RS232
Input Port qty: 6 Ports
Output Port qty: 32 Ports
Remote control, Timing control and Scenario linkage can be realized through the mobile phone
Knowledge Base
Disk Downloads
Disk for KC868-H32 Controller (APP, PC software, VirCom tool)
Sample Code
Videos
