We improved ethernet wifi relay module — KC868-H32B for smart home automation DIY. The new model called “KC868-H32B”. What’s the difference between “KC868-H32B” and “KC868-H32L”?
3:Ethernet and WiFi module wokr mode control by setting buttons and have LEDs for show work status.
There are some FAQ about new amaze function of KC868-H32B. It’s COOL!
Q1. If there is no Internet, can we use KC868-H32B?
Q2. How can KC868-H32B be used in both local LAN and Internet WAN?
KC868-H32B adopts dual core network communication module. Ethernet and WiFi can be configured to work in different network environment modes at the same time.One is work in local network , another is work for remote connect with cloud server.
Q3. How to ensure the reliability of KC868-H32B network?
For example, both Ethernet and WiFi are set to Internet UDP mode to connect to the cloud server. When the cable network is disconnected or WiFi is disconnected, KC868-H32B will automatically switch the Ethernet / WiFi line to keep the communication with the cloud server smooth.
Q4. If house power failure, will relay output state of KC868-H32B be automatically restored?
KC868-H32B will automatically restore the relay state before power failure. For example: before the power failure, 1-3 lights are ON; when power on again, the 1-3 lights will be turned ON automatically.
Q5. If there is power failure at home and power supply is restored, do you need to restart KC868-H32B?
Without restart, KC868-H32B will automatically work without manually reboot.
Q6. How to use multiple KC868-H32B?
Multiple KC868-H32B only need to be connected to the router for network. Multiple KC868-H32B can be added to one mobile app account.
Q7. Can multiple people use KC868-H32B at the same time?
The administrator can authorize multiple people to use one or more KC868-H32B.
Q8. Does KC868-H32B support developers in software for development?
KC868-H32B open protocol, support use your own software to control relay and read state and provide demo source code.
Q9. Does KC868-H32B support Raspberry Pi and Ardiuno?
Q10. Does KC868-H32B support third-party open source smart home platforms such as Node-Red and Home Assistant?
