KC868-H32W smart control box is the WiFi version of KC868-H32 smart control box. Both functions and interfaces are identical. KC868-H32W connects the Internet through WiFi wireless, and KC868-H32 connects the Internet through Ethernet interface.
Description
Products Function:
1.Remote ON/OFF – Turn electrical devices ON/OFF from anywhere
2.APP/PC Support– Free iOS and Android mobile App and PC software
Applications:
- Home Automation
- Lighting Control
- Garden Equipment Control
- Industrial Automation
- Test Fixtures
- DIY and Hobby
Products Features:
Products Parameter (Specifications):
Dimension: 272x117x40mm
Working Voltage: DC 12V
Working Temp: -20℃~70℃
Output Load:each 250V/5A
Input port qty:6 ports
Output port qty:32 ports
KC868-H32 Interface Definition Diagram
This is KC868-H32’s PC software of remote control version, It support rename and change ICO file by yourself. Also support kinds of languages of different countries.
This is Config window. Set device name and ON ICO and OFF ICO file.
This is main window. All device can be controled.
PC software support ipcamera CCTV (only use for KinCony’s ipcamera product). When you see the video control the relay switch. 2 cctv screen.
If you connect with “KC868 Voice Assistant” module, controller can control voice control by Amazon Alexa or Google Home Speaker or Amazon Alexa or Google Home phone APP.
KC868-H32 Application Solution — Smart Lighting Control
If the load is larger than 700W, the power expansion can be achieved by using solid state relay. Its working principle is as follows:
Security and Intelligent Linkage Control Solution
Intelligent Remote Pumping & Irrigation Solution
Remote Access Controlling Solution
Servers Restart Remote Controlling Solution
Power Strip Intelligent Controlling Solution
Intelligent Power Distribution Box Solution
For Development Communication Protocol
We supply complete source program Toolkit of VS2005(Microsoft Visual Studio 2005) , and we give the controlling examples through RS232 serial port and Ethernet socket,to help customers carrying on the secondary development.
The computer software can control the relay switch, and also show the input state.Details showed from below screenshots.
We can supply the DEMO code of C++Builder, Delphi, VB.Net, Python and iOS versoins.
Knowledge Base
Disk Downloads
Disk for KC868-H32 Controller (APP, PC software, VirCom tool)
Sample Code
Videos
How to config wifi with KC868-H32W smart home controller
