Products Parameter:
Dimension: 108x117x40mm
Working Voltage: DC 12V
Working Temp: -20℃~70℃
Output Load:each 250V/10A
Communication mode:WiFi/RS232
Input port qty:4 ports
Output port qty:4 ports
The following information introduces KC868-H4 4 channel wifi relay module. KC868-H4, KC868-H2, KC868-H8, KC868-H32 controller are KC868 series of KinCony’s products, so phone APP and PC software are compatible. There are only different input and output channel.
Packaging:
Products Function:
2. Remote controlling the opening/closing of 8 routes or 8 groups’ circuits.
3. Supporting 8 ports input of sensor switching value.
4. Supporting secondary development
5. Supporting APP remote controlling
6. Widely used for lights controlling of kinds of occasion (like Indoor, theater or Amusement Park etc) and switching of mechanical equipments, and management of the computers in the cyber bar and so on.
Products Features:
2. each route is equal an independent switch.
Products Usage Instructions Wiring and Installation
2. Connecting the lamp and power with relays output COM and NO port.
3. When need to control one group or groups lights, connecting the line into the corresponding output poles.
4. Connecting the 12V power adapter to charge.
5. When the detection sensors are available, connecting them into the input port.
This is PC software for KC868-H4 4 channel ethernet relay module, It can control by LAN (local control) or WAN (remote control)
new software support CCTV (only use for KinCony’s ipcamera product). When you see the video control the relay switch.
This is config menu, The title and copyright and all relays’ name can be changed by yourself.
If you connect with “KC868 Voice Assistant” module, controller can control voice control by Amazon Alexa or Google Home Speaker or Amazon Alexa or Google Home phone APP.
Knowledge Base
Disk Downloads
Disk for KC868-H4W Controller (APP, PC software, VirCom tool)
Sample Code
Videos
