Description 51 MCU GPS development board, LCD screen can display real-time GPS data: GPS time, latitude, longitude, altitude and other information, development board provides TFT LCD and 12864 color screen interface. Development board uses SMD component designed , you can use an external power supply or USB power cable for notebook users, because of outdoor debugging, laptop or netbook can use USB cable for power supply and at the same time development board provide an external RS232 serial communication interface, user programming the code and burn into chip by PC com port, while the board has jumpers for switch communication mode ,there are three communication modes, respectively : PC – GPS module; PC – MCU; MCU -GPS module.
Demo Description
now you can see the information on TFT-LCD, it’s more beautiful then 12864 LCD, the image on screen is not very clearly because of the camera shutter speed. The following is PC test DEMO for GPS . Firstly set the COM port, such as COM1 or COM2… . Then give power for GPS board, you will see the information about satellites later.
This is GPS antena for SMA interface. Packaging Details
If you can see this, then you might need a Flash Player upgrade or you need to install Flash Player if it’s missing. Get from Adobe. This error may appear if the URL path to the embedded object is broken or you have connectivity issue to the embedded object. |
