We improved ethernet wifi relay module — KC868-H8B for smart home automation DIY.
3: Ethernet and WiFi module wokr mode control by setting buttons and have LEDs for show work status.
4: Add “COM”, “NO”, “NC” 3 ports for every relay output.
