kc868-ha
KC868-HA RS485 Button Adapter Released
We have designed KC868-HA RS485 button adapter, let your old switch or traditional switch become smart, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel work with your smart home automation. This time, regular switch can be used in smart home system.
kc868-ha
How to use KC868-HA RS485 button adapter
Hardware diagram: How to config: a. Use USB-RS485 adapter connect to KC868-HA. b. download KC868-HA config tool and open it Chose your USB Serial port, baud is “9600”, parity: None click “OPEN” button. Target Relay Controller Addr: it’s your relay controller’s RS485 address, such as we use KC868-H32B Pro or KC868-A series board’s RS485 setting…
kc868-ha
RS485 MODBUS Button Adapter – KC868-HA
KC868-HA let your old switch or traditional switch become support RS485 modbus protocol for KinCony’s relay controller, work with KC868-H32B Pro smart relay controller, use any “Latch” or “Momentary” switch panel work with your smart home automation. PC software download: https://www.kincony.com/download/HA485_Ctrl_V1.0.4.0904.zip How to use KC868-HA online guide: https://www.kincony.com/how-to-use-rs485-button-adapter.html KC868-HA protocol for RS485 relay board: https://www.kincony.com/download/KC868-HA-protocol-for-RS485-relay-board_v106.pdf…
how to use KC868-AK programmable keyboard
Hardware connection of KC868-AK ESP32 programmable keyboard: You can use 1-35 buttons for defined actions. You can use 1-36 terminal ports with extend momentary wall switch, extend cable MAX 1000 meter. Connect with relay controller by RS232 or RS485 cable. here is typical case KC868-AK work with KC868-H32B Pro smart relay controller and contact diagram:…
KC101
KC101 Tuya Electronic DIY Kit Released
We have developed the first DIY product for smart home enthusiasts to cultivate everyone’s interest in electronic technology. “KC101” is 4 channels universal WiFi wireless smart switch with RF 433MHz module, it’s a DIY kit for DIYer. it for your smart home system to remotely and automatically turn ON/OFF home appliances and electronic devices by…
KC101
KC101 Tuya electronic DIY kit
KC101 is 4 channels tuya universal WiFi wireless smart switch with RF 433MHz module, it’s a DIY kit for DIYer. it for your smart home system to remotely and automatically turn ON/OFF home appliances and electronic devices by mobile phone APP. It also can be controlled by 433MHz RF remoter. It can connect and control…
kc868-e16v2
KC868-E16 V2 Extend Din Rail Relay Module Released
We have designed new version KC868-E16 V2 extend relay module. Now every relay have COM, NO, NC port and use by metal manual control switch buttons. Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO,NC Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃ Relay consumption: 0.53W/each Mechanical life:…
kc868-e16v2
KC868-E16 V2 DIN Rail Relay Module
KC868-E16v2 relay module introduce Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO,NC Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃ Relay consumption: 0.53W/each Mechanical life: more than 5 million times Electrical life: (under rated control capacity) more than 100,000 times (ON-OFF frequency 20 times/minute) Maximum operating frequency:…
kc868-h32b pro
How to use arduino library for KC868-H32B Pro
We have made arduino library for KC868-H32B Pro smart controller. it is open source and free for DIYer use. 1. Install ESP32 USB driver to your computer. download from: https://www.kincony.com/download/CH341SER.zip after installed USB driver, connect USB cable to your KC868-H32B Pro USB port. Then you will find COM port in windows OS “device manager” 2. Enable “ESP32…
kc868-e8t
KC868-E8T ESP32 Tuya 4G Energy Meter Relay Module Released
We have designed KC868-E8T with Tuya module , 4G LTE module and ESP32, the 8 channel removable relay board. You can integrate KC868-E8T to home assistant by ESPHome use follow resource: a. 8 relay relay, 8 channel digital input for switch panel. 4 channel AC220V energy meter (BL0939 energy chip) for load’s voltage, current, power,…
