WiFi DIN Rail switch
WiFi DIN Rail switch module released!
WiFi DIN Rail switch module made by TUYA wifi module, use TUYA mobile phone application. support iPhone and android phone. work voltage AC110V or AC220V. You can use this wifi switch connect with AC contactor, so that let your AC contactor become smart. Support 1 phase or 3 phase AC contactor. it can use for…
WiFi DIN Rail wifi switch module
WiFi DIN Rail wifi switch module made by TUYA wifi module, use TUYA mobile phone application. support iPhone and android phone. work voltage AC110V or AC220V. You can use this wifi switch connect with AC contactor, so that let your AC contactor become smart. Support 1 phase or 3 phase AC contactor. it can use…
home automation training -22-add RGBW LED strip to home assistant by ESPHome
home automation training -22-add RGBW LED strip to home assistant by ESPHome   1. chose LED strip model 2. connect with wire: VCC,DATA,GND 3. config in ESPHome: light: – platform: fastled_clockless chipset: WS2812B pin: GPIO33    # Pin Define connected with LED strip num_leds: 30  #LEDs number rgb_order: GRB name: “led_strip” effects: – addressable_rainbow: …
home automation training -21-Install Raspbian OS on KC868-Server raspberry pi CM4
home automation training -21-Install Raspbian OS on KC868-Server raspberry pi CM4   https://www.raspberrypi.com/software/ 1. Change KC868-Server USB boot jumper 2. Connect with USB cable with computer and KC868-Server 3. Power on of KC868-Server 4. Run rpiboot 5. Download and install Raspberry Pi Imager 6. Manually install an operating system image 7. Connect KC868-Server HDMI…
home automation training -20-extend digital output & input in home assistant
home automation training -20-extend digital output & input in home assistant   extend output and input ports by hardware devicea. KC868-A series board  (integrate to home assistant by ESPHome) b. KC868-HxB series board (integrate to home assistant by MQTT) 2. config ESPHome for KC868-A16 esphome: name: kc868-a16 platform: ESP32 board: esp32dev # Example configuration entry…
home automation training -19-water level sensor for automation in home assistant
home automation training -19-water level sensor for automation in home assistant   Chose water level sensor:a. output dry contact for OPEN/CLOSE singal. b. output DC 0-5v analog voltage. 2. create a new automation: water-level-control-output4-on (turn on relay) ——————————————- Trigger type: State Entity: input-1 To: on Actions: Action type: Call service Service: Switch:Switch: Turn on + Choose…
home automation training -18-ZigBee motion sensor control light in home assistant
home automation training -18-ZigBee motion sensor control light in home assistant   SONOFF SNZB-03 configure for home assistant by Zigbee2mqtt sensor: – platform: mqtt name: pir-state state_topic: “zigbee2mqtt/0x00124b00251e530f” value_template: “{{ value_json.occupancy }}” Note: ID need replace with your device. such as ‘0x00124b00251e530f’ 2. create a new automation: create automation-1 (turn on light) ——————————————- Trigger…
home automation training -17-integrate USB local camera to home assistant
home automation training -17-integrate USB local camera to home assistant   1. connect with your USB camera. 2. Enable home assistant “Advanced Mode”. 3. “Add-ons, Backups & Supervisor” — “system” — “Host” — “Hardware” ,  search videox 4. Configuration edit yaml camera: – platform: ffmpeg name: cam input: /dev/input/video0 5. Home assistant restart 6.…
home automation training -16-integrate device to home assistant by Zigbee2MQTT
home automation training -16-integrate device to home assistant by Zigbee2MQTT   Add the repository URL under Supervisor->Add-on store->…->Manage add-on repositories: https://github.com/zigbee2mqtt/hassio-zigbee2mqtt 2. Zigbee2mqtt add-on Configuration for home assistant data_path: /config/zigbee2mqtt external_converters: [] devices: devices.yaml groups: groups.yaml homeassistant: true permit_join: false mqtt: base_topic: zigbee2mqtt server: mqtt://192.168.1.96:1883 user: mqtt password: ‘123’ serial: port: /dev/ttyACM0 advanced: log_level:…
home automation training -14-integrate temperature sensor to home assistant
home automation training -14-integrate temperature sensor to home assistant   DS18B20 temperature range: -55°C to +125°C and is accurate to ±0.5°C this is the ESPHome config: # Example configuration entry dallas: – pin: 4 update_interval: 5s # Individual sensors sensor: – platform: dallas address: 0x69062162d9ec4328 name: “Temperature” YouTube: https://www.youtube.com/c/KinCony
KC868-A32 esp32 board hardware design details
How many relays can be installed on the controller board? Four? Eight? Kincony decided not to limit itself and equipped its KC868-A32 model of ESP32 board with as many as 32 relays. The result was a unique controller, which I don’t remember any analogues – against the background of ordinary devices of this type, the…
