home automation training -1 Course introduction
Hello, everyone, This article / video I will show you why we make these smart home automation lessons.Because the smart home is not a simple subject. It is a comprehensive application of network, software, hardware, cloud computing, artificial intelligence and big data.It will not only involve the WAN, LAN, operating system and program that we…
kc868-e16s
KC868-E16S ESP32 DIN Rail relay module released!
we have designed KC868-E16S ESP32 home automation extend relay module. it’s based on ESP32 , Ethernet + RS485 + 4CH analog input + 16CH digital input ( include manual control buttons ) and 16CH digital output by 16A OMRON relay. Support ESPHome for home assistant and Tasmota firmware for home automation DIY.
kc868-a64
KC868-A64 ESP32 home automation GPIO module released!
We have designed KC868-A64 smart controller , so much GPIOs for user. 64 channel digital input and 64 channel digital output and 4 channel analog input, “Made For ESPHome” , easy integrate to home assistant. KC868-A64 support write arduino IDE code download to ESP32 module for home automation project.
KC868-AG: IoT IR controller
I don’t know about you, but my first association when looking at the Kincony KC868-AG is a hockey puck. In fact, this is another IoT controller from Kincony based on the popular ESP32 microcontroller, designed for IR control of home equipment and additionally equipped with a 433 MHz wireless receiver and transmitter for interacting with…
KC868-A4 Green house temperature monitoring
In this series, we will analyze examples of the application of Kincony controllers in solving cases from practical applications. Practical cases are usually not complex, but they solve important things in the production process. In some cases, mistakes can cause large losses in production. Such systems need to be approached seriously. author: wrote by Nebojsa…
How to use KC868-Server
[vc_row][vc_column][vc_column_text]1.Diagram of relay Controller Download PDF details Leds status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White: network run in “TCP Client” mode or “MQTT” mode. Yellow: network run in “TCP Server” mode. Blue: network run in “UDP” mode. what’s UDP , TCP Server, TCP…
