esp32 4g
KinCony G1 ESP32-S3 SIM7600E 4G Module released
KinCony G1 ESP32 4G module based on ESP32-S3-WROOM-1U (N16R8) and SIMCOM SIM7600E series chip. G1 have RS485 port and many free GPIOs for user.You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. Everyone can modify and change the code for your own smart home automation system…
esp32 4g
ESP32-S3 SIM7600E 4G Module – KinCony G1
sim7600e
KinCony SIM7600E-L1C 4G breakout LTE core module released
The SIM7600E-L1C is a versatile and cost-effective 4G LTE module that integrates multiple communication functionalities, making it suitable for a wide range of IoT and M2M applications. Developed by KinCony, this module provides robust connectivity and high-speed data transmission capabilities, ensuring seamless integration into IoT ecosystems. USB-C: connect with SIM7600E’s USB port , debug by…
sim7600e
how to use “KCS”v3 firmware for KinCony ESP32-S3 board
Note: This document use for KinCony KCS v3 firmware smart controller. 1. Download “KCS” firmware to KinCony ESP32-S3 series board. a. Download “ESP32 download tool” from https://www.kincony.com/wp-content/uploads/2022/08/flash_download_tool_3.9.2.zip and firmware BIN file from KinCony forum. b. Open “flash_download_tool_3.9.2.exe”, (firstly MUST connect USB cable to your board, power on) chose “ESP32-S3” and workMode=“develop”  loadMode: “usb” item. c.…
esp32-s3 voice assistant
KinCony AS ESP32-S3 voice assistant released
KinCony ESP32-S3 voice assistant based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It use by I2S INMP441 microphone and MAX98357A amplifier. SD card socket on PCB. there are WS2812B RGB LED you can use for assistant. It also have IR receiver and many free GPIOs on PCB. Model No. KinCony AS Description: KinCony ESP32-S3 voice assistant –…
ESP32-S3 voice assistant – KinCony AS
esp32 tuya relay
KinCony F16 ESP32-S3 16A Removable Relay Board released
KinCony F16 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. It have 16 manual control switch buttons can turn ON/OFF relay even if system is broken. 16 channel removable OMRON high-quality relay, 4 channel 1-wire GPIOs, 2 free GPIOs, 4 channel analog input ports. One SD card using SPI bus. KinCony F16 include DS3231…
KinCony B16M ESP32-S3 Smart Controller released
KinCony B16M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B16M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya…
ESP32 Smart Controller – B16M (16CH MOSFET)
Video campaign
KinCony Video campaign: Share Your Project, Earn Rewards!
KinCony Video Submission Campaign: Showcase Your Project and Get Rewarded! Dear Valued KinCony Customers, We’re excited to launch a new campaign where you can share how you’re using KinCony products in your projects and help inspire other users! Simply create a short, real-life video showcasing KinCony products in action, and in return, you’ll receive rewards…
