made-for-esphome
KC868-A4 send infrared signal control TV configure for ESPHome
esphome: name: kc868-a4 platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: wifi: ssid: “KinCony” password: “xxxxxxxx” captive_portal: web_server: port: 80 remote_receiver: pin: number: 23 inverted: True dump: all remote_transmitter: pin: number: 22 carrier_duty_percent: 50% switch: – platform: template name: “TV Power” turn_on_action: – remote_transmitter.transmit_nec: address: 0x00BD command: 0x807F repeat:…
made-for-esphome
KC868-Uair work with home assistant by ESPHome configure
This is ESPHome configure for KC868-Uair smart home automation box. example for use inside temperature sensor (DS18B20) and extend temperature sensor (SHT3x)   and WS2812B RGB LED strip.   esphome: name: kc868-uair platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: ota: password: “978e66f878ed5041b830cfb427393c79” wifi: ssid: “KinCony” # your wifi router…
made-for-esphome
KC868-A4 wifi work with home assistant by ESPHome configure
This is ESPHome configure for KC868-A4 smart home automation board. example for use output1-4 and input1-4 by GPIOs. esphome: name: kc868-a4 platform: ESP32 board: esp32dev # Enable logging logger: # Enable Home Assistant API api: ota: password: “4d5a388de4f759bf88e71cde7a31af6f” wifi: ssid: “KinCony” password: “a12345678” # Enable fallback hotspot (captive portal) in case wifi connection fails ap:…
made-for-esphome
KC868-A8 ethernet work with home assistant by ESPHome configure
This is ESPHome configure for KC868-A8 smart home automation board. example for use output1-8 and input1-8 by PCF8574 IIC chip. esphome: name: kc868-a8 platform: ESP32 board: esp32dev # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT…
made-for-esphome
KC868-A16 ethernet work with home assistant by ESPHome configure
This is ESPHome configure for KC868-A16 smart home automation board. example for use output1-16 and input1-16 by PCF8574 IIC chip. esphome: name: kc868-a16 platform: ESP32 board: esp32dev # Example configuration entry for ESP32 i2c: sda: 4 scl: 5 scan: true id: bus_a # Example configuration entry ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT…
kc868-e16
KC868-E16 DIN Rail Relay Module
KC868-E16 DIN Rail Relay Module introduce: Inside relay model : OMRON G2R-1-E SPDT every channel output : COM,NO Coil voltage: 12V MAX current: 16A at 250VAC Operation Temperature: -40~55 ℃ Relay consumption: 0.53W/each Mechanical life: more than 5 million times Electrical life: (under rated control capacity) more than 100,000 times (ON-OFF frequency 20 times/minute) Maximum…
rc snubber
RC Absorption Snubber Circuit Module
RC absorption snubber circuit module used on protecting the relay or thyristor because it can avoid damage that from inductive electromotive force generated by the inductive load when on or off. Preventing electromagnetic interference and increasing the anti-jamming capability of the microcontroller. For AC or DC 5 ~ 400V inductive load (less than 1000W), protection…
