Apply free sample of KinCony IoT product
Apply For Free Sample of KinCony Product 1. Available free sample product: KC868-A4 ESP32 board, KC101 Tuya electronic DIY kit KC868-A4: https://www.kincony.com/arduino-esp32-4-channel-relay-module.html KC101: https://www.kincony.com/tuya-electronic-diy-kit-kc101.html 2. Application conditions (in one of the following conditions) —-A. free education (free education based on KC868-A4 or KC101) To launch the open source projects of free education based on KinCony…
8-integrate KC868-COL sensor
how to DIY home automation by home assistant guide: 1: how to install home assistant on raspberry pi4 linux system. 2. install node-red on home assistant raspberry pi4 3. make phone application button to control light relay switch 4. how to install wall switch and wireless remoter on home assistant 5. how to use input…
8 channel dimmer
KC868-D8 NEW FIRMWARE FOR MQTT AND HTTP FUNCTIONS
improvement: 1. add 8 channel dimmer control by webpage. 2. support http command for developer integrate to third-party software to change brightness and read output brightness. 3. add web config password. 4. RS485 address set by webpage. 5. support use MQTT function. it will easy integrate to third-party software, like home assistant… how to integrate…
home assistant
KC868-D8 INTEGRATE HOME ASSISTANT BY MQTT
Now KC868-D8 can easily integrate to home assistant by MQTT, use for 8 channel dimmer output. step-A. Make sure KC868-D8’s firmware version is >= V4.34. you can download new firmware from our technical support forum: https://www.kincony.com/forum step-B. open controller’s IP, set ethernet work mode = MQTT, set the MQTT server IP and port,Mqtt Broker username…
smart rack
KC868-1U-8 Smart Rack Power Strip Controller Released
We have designed Smart Rack Power Strip Controller – KC868-1U-8 based on KC868-H8B smart relay controller. so the function as same as KC868-H8B. KC868-1U-8 is 8 channel relay output, use MAX AC230V 30A relay. It mainly install by network cabinet, support local or remote control by mobile phone app or computer software. it can use…
smart rack
4 channel wifi ethernet relay
KC868-H4B NEW FIRMWARE FOR MQTT AND HTTP FUNCTIONS
improvement: 1. add relay control by webpage 2. support http command for developer integrate to third-party software to tun on/off relay and read relay state. 3. add web config password 4. add read input state http command for developer integrate to third-party software. you can send http command to get information of 4 channel digital…
