4 channel wifi ethernet relay
KC868-H4B NEW FIRMWARE FOR MQTT AND HTTP FUNCTIONS
improvement: 1. add relay control by webpage 2. support http command for developer integrate to third-party software to tun on/off relay and read relay state. 3. add web config password 4. add read input state http command for developer integrate to third-party software. you can send http command to get information of 4 channel digital…
KC868-COLBS
KC868-COLBS Programmable Logic Controller Released
KC868-COLBS Logical Controller is improved on the basis of KC868-COLB: 1. add 8 channel internal relay. use jump set for “internal relay” or extend relay module. Extend relay module MAX support 32 channel output. 2. internal relay MAX support AC277V 10A, every output have “COM,NO,NC” output option.
KC868-COLBS
Programmable Logic Controller(Network+Relay) – KC868-COLBS
KC868-COLBS Logic Controller is improved on the basis of KC868-COLB: 1. add 8 channel internal relay. use jump set for “internal relay” or extend relay module. Extend relay module MAX support 32 channel output. 2. internal relay MAX support AC277V 10A, every output have “COM,NO,NC” output option. YouTube video tour: https://youtu.be/wZSpDiWLcBI KinCony technical support forum:…
smart DB
smart distribution board (MCB box) – case16
distribution board customsize design: Functions: 1. remote / locally control 32 channel AC220V 1 phase power output by mobile phone and PC application. 2. use “Omron” removable relay module. 3. use dry contactor sensor trigger output power. 4. support connect with analog DC 0-5v sensors and digital sensors and DS18B20 temperature sensors. 5. input sensors…
ip scan
KinCony Smart Controller IP SCAN tool launched
We developed KinCony smart controller IP scan tool for easy to find out controller’s IP address, this tool use for “B” or “BS” series controller. It will scan all KinCony device in same network. Step1: chose your network device of your computer. Step2: click “StartMonitorPort” button. Step3: click “SCAN” button. Now all KinCony Controller (KC868-HxB…
distribution panel
smart distribution board (MCB box) – case15
distribution board customsize design: Functions: 1. remote / locally control 5 channel DC24V valve and one 3 phase pump (motor) by mobile phone and PC application. There are 5 switch buttons on the panel for manually control. 2. use dry contactor sensor trigger output power. 3. support connect with analog DC 0-5v sensors and digital…
mqtt home assistant
KC868-H8B new firmware for MQTT and HTTP functions
improvement: 1. add relay control by webpage 2. support http command for developer integrate to third-party software to tun on/off relay and read relay state. 3. add web config password 4. add read input state http command for developer integrate to third-party software. you can send http command to get information of 6 channel digital…
