ESP32-S3 Smart IR Controller
KinCony AG8 ESP32-S3 Smart IR Controller released
We have designed ESP32-S3 Smart IR Controller – KinCony AG8. it support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, RS232, 1-wire GPIOs, 8 channel IR sender terminal.  Support expand infrared emission tube for long distance cable. board support both wifi and ethernet port. It can use for smart home…
How to use KBOX APP for relay board work without internet
the KBOX app (iPhone and android OS), use for KinCony 2,4,8,16,32 channel relay controller. it use in local network without internet. download from here: https://www.kincony.com/document add relay controller according to IP address and Port. for example: add 32 channel relay controller by IP address and Port. relay board should enabled “TCP Server” work mode firstly.…
How to use (A32 Pro/A32/H32B Pro/H32BS/H32B/H32) relay controller PC software
the PC software for Windows OS, use for KinCony A32 Pro/A32/H32B Pro/H32BS/H32B/H32 32 channel relay controller. download from here: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip add 32 channel relay controller by IP address and Port. relay board should enabled “TCP Server” work mode firstly. if you are using KinCony A32 Pro controller, just set “TCP Server” work mode in “KCS”…
ESP32-S3 Core Board
KinCony ESP32-S3 Core Board released
We have designed ESP32-S3 Core Board – KinCony S3. it’s mini PCB, support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, I2C bus, 1-wire, analog input ports. analog input port can use for VOLTAGE / CURRENT signal set by jumper. It have ethernet port, also have SIM7600 4G module and…
ESP32-S3 Core Board
esp32 sd card
KinCony ATF ESP32 SD Card Module released
We have designed ESP32 SD card module – ATF. it can record data save file to SD card. It need you write arduino code. for example, you can receiver serial data write LOG file to SD card. You can read digital input sensor or temperature humidity sensor write to SD card. it’s easy integrate to…
esp32 relay board
KinCony A32 Pro 32 Channel ESP32 Relay Board released
KinCony A32 Pro ESP32 relay board based on ESP32-S3-WROOM-1U (N16R8) wifi chip, it have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. Support 32 channel relay output and 2 channel dc 0-10v dimmer output, 2 channel 1-wire GPIOs, 4 channel analog input ports. It support 4G module (SIM7600 series)…
esp32 relay board
32 channel 4G ESP32 relay board – A32 Pro
esp32 sd card
