mqtt input module
KC868-COLB NEW FIRMWARE SUPPORT ETHERNET FOR MQTT
improvement: 1. KC868-COLB default set “enable” for auto upload function, before version default is “disable”. 2. Fixed problem that if have a DS18B20 temperature value auto loaded, other temperature sensors will stop upload, until temperature value changed will auto upload again. Now all DS18B20 temperature sensor will all auto upload. 3. Support use MQTT function…
home assistant
KC868-COLB input module integrate home assistant by MQTT
Now KC868-COLB MQTT input module can easily integrate to home assistant by MQTT, use for 16 channel digital input + 16 channel analog input + 5 channel DS18B20 temperature sensor. A. make sure KC868-COLB’s firmware version is >= V1.8. you can download new firmware from our technical support forum: https://www.kincony.com/forum B. open controller’s IP, set…
pc control relays
new open source PC software for all KC868 smart controllers
MulitiBoardCtrl tool is windows software for PC and tablet. it support use KC868 all relay controller model and all KC868-COL/COLB logical controller. 1. one software window support MAX 254 device (relay board+COL/COLB board). if you add 254 units of KC868-H32B, then you can control total 254*32=8128 channels relay output. 2. we have add the log…
mqtt home assistant
KC868-H32B new firmware support WiFi for MQTT
improvement: 1. add read input state http command for developer integrate to third-party software. you can send http command to get information of 6 channel digital input port state. Command is like this, send: http://192.168.1.xx/sw_ctl.cgi?RelayFF=RD&postpwd=XXXXXX Then will feedback all state. 2. support use MQTT function by WiFi. it will easy integrate to third-party software, like…
home assistant
KC868-H32B integrate home assistant by MQTT
Now KC868-H32B can easily integrate to home assistant by MQTT, use for 32 channel relay output and 6 channel digital input port. A. make sure KC868-H32B’s firmware version is > V4.24. you can download new firmware from our technical support forum: https://www.kincony.com/forum B. open controller’s IP, set the wifi module or ethernet work mode =…
esp8266 google home
ESP8266 source code for Alexa and Google Home speaker
firstly thanks to vmarandola , he have writen the arduino code for KinCony’s voice module (based on ESP8266 wifi module). here is his github link for source code: https://github.com/vmarandola/KinconyAlexaGoogle if you have voice module, you can DIY by this code, it support by Google home and Alexa speaker for voice control. Also have scene mode and timer function.…
http relay
KC868-H32B new firmware for HTTP webpage control relays
KC868-H32B relay controller support http webpage control. It can control by http command for software engineer. firmware V4.0.1 improvement: 1. add relay control by webpage 2. support http command for developer integrate to third-party software to tun on/off relay and read relay state. 3. add web config password firmware download : https://www.kincony.com/forum/showthread.php?tid=220&pid=679#pid679 KC868-H32B relay controller…
How to use KC868-COLB Programmable logic controller
[vc_row][vc_column][vc_column_text]1.Diagram Led status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White: network run in “TCP Client” mode. Yellow: network run in “TCP Server” mode. Blue: network run in “UDP” mode. (Not used now) what’s UDP , TCP Server, TCP Client means: When set to “TCP…
smart home video
Make demo video became KinCony’s distributor
This is video demo tour make from Czech Republic: Why need you make smart home demo video then become distributor? Order KinCony’s mainly IoT smart home automation products in our online store. You use products successfully and we will supply technical support. Make demo videos by yourself in your local language, Because you can make…
16 Channel Powerful Smart Distribution Box DIY
Here is the Ultimate Smart Home Tour for 16 Channel Smart Power Distribution Board DIY mainly used by KC868-H16B Smart Relay Controller and KC868-COLB logical controller and power meters. Step by step, it’s very easy to DIY. Perfect for Smart home automation DIY. Smart Controller also can connect with Arduino or Nodemcu or Raspberry PI.It…
