how to use 32-16 channel relay board PC software in WAN
How to use 32-16 channel relays board PC software in WAN for remote control. Software download from: https://www.kincony.com/document
How to use KBOX smart home automation phone APP control KC868-Hx relay board in LAN(no need internet) App download from : https://www.kincony.com/document
Here is the Ultimate Smart Home Tech Tour for KinCony’s IoT module DIY. Step by step, it’s very easy to DIY. Perfect for Smart home 2020. 1. Different wireless protocol 2. Feature of different wireless 3. Which kind of wireless product to choose 4. Wireless product structure
Here is the Ultimate Smart Home Tech Tour for Smart Home Automation Project DIY used by KinCony’s KC868 Smart Controller. It’s very easy to DIY. Perfect for Smart home 2020. Smart Controller also can connect with Arduino or node MCU or a raspberry pi. It is an open protocol and has a demo source…
Here is the Smart Home Automation DIY Project use by KinCony’s KC868 smart network relay module and self-reset switch button. It’s very easy to DIY. Perfect for Smart home 2020. Smart Controller also can connect with Arduino or node MCU or a raspberry pi. It is an open protocol and has a demo source…
This video circuit diagram of the Smart Power Distribution Box is based on video link: https://youtu.be/URHqefy8FzM This is 3 units 3 phase + 23 units single phase DB. According to the principle of the circuit diagram, you can DIY out various channel versions by yourself.
This video tells you how to read power meter voltage current frequency by RS485, send data to KC868-COL, read all data on PC software.
1. KC868-COL cooperates with the KC868-Hx relay controller to work as an automatic control system. KC868-COL is the AI brain and KC868-Hx is the actuator. KC868-COL uses the IFTTT command locally without the Internet. 2. Watch all sensors data on PC in real-time and do automatic control as a user preset. 3. Like a…
[vc_row][vc_column][vc_column_text]1.Diagram of relay Controller A.KC868-H32BS B.KC868-H32B C.KC868-H16B D.KC868-H8B E.KC868-H4B F.KC868-H2B Led status different color means: Red: Controller is power on. Green: WiFi module is connect to your router successfully. White: network run in “TCP Client” mode. Yellow: network run in “TCP Server” mode. Blue: network run in “UDP” mode. what’s UDP , TCP Server, TCP…
