Led dimmer switch by homekit
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost no need to write any program code. This video shows how to configure the Node-RED control device by 8 channel dimmer controller by apple home kit by Raspberry…
RF remote control by homekit
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost no need to write any program code. This video shows how to configure the Node-RED control device by RF signal (radio frequency) by apple home kit by Raspberry…
infrared remote control anything
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost no need to write any program code. This video shows how to configure the Node-RED control device by infrared signal by dashboard by Raspberry Pi 4 with Linux…
make sensor monitoring service
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost no need to write any program code. This video shows how to configure Node-RED for kinds of digital and analog sensor monitoring by dashboard by Raspberry Pi 4…
How to control 32 relay module using Arduino
 This video shows how to use the Arduino program to control 32 channel(KC868-H32L) ethernet relay module by serial communication. Here is the Ultimate Smart Home Tech Tour for KinCony’s IoT module DIY. Step by step, it’s very easy to DIY. Perfect for Smart home 2020.
web application by dashboard
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open-source. I find it’s very easy to use, almost not need to write many program codes. This video shows how to configure Node-RED for website application by dashboard on iOS and android and PC computer by Raspberry…
Wall switch button for homekit
 We will produce a series of video tutorials using the IBM Node-Red DIY software. The Node-Red is open source.I find it’s very easy to use,almost not need write many program code. This video shows how to configure Node-RED for update wall switch button status on apple iPhone or iPad homekit by Raspberry Pi 4…
