home automation app
KinCony Smart Home APP update for add TOUCH mode
“KinCony Smart Home APP” android phone app updated, we have added new functions: 1. Add login window supports multiple account switching and adds the function of remembering password. 2. Fixed the bug that the authorized sub account number must be a digital account number. Now, the account number can be authorized regardless of the number…
KC868 Smart Controller firmware download update tool released
We have make firmware update tool for KC868-Hx smart relay controller and KC868-COL Programmable Logic Controller (analog input digital input module). If the product serial number like “HxxBxxxxxxxxxxxx” , include “B” in SN, then you can use this firmware software update kit. We will continue to update the kc868 series products, through the update firmware,…
data acquisition
analog input digital input module – KC868-COL
KC868-COL acquisition board (analog input digital input module) is used to read AI, DI, Temperature,electricity meter . The equipment supports 5 channel of DS18b20 temperature sensors, 16 channel of Digital input signal detection, 16 channel of Analog input signal detection and RS485 communication smart meter. KC868-COL have two version of firmware, this website version is…
power meter
KC868-COL update for support power consumption meter monitor
We have updated new firmware of KC868-COL and new PC software. update function as follows: Support 8 power meter monitor for Power consumption,voltage, current, frequency, power factor, active power value. Support input trig hold time minimum =0.1 second can be used. Support custom define RS485 command for “THEN” output command. You can use sensor automatic…
smart home app
KBOX iOS app update for scene mode
“KBOX” iOS phone app updated, we have added new function: 1. update add controller scene mode, support add KC868-H2/H4/H8/H16/H32 you can add any controller’s any relay switch output to scene mode.Set for ON,OFF or not change.
8 channel dimmer
8-Channel Dimmer – KC868-D8 released
We have designed the KC868-D8 for 8 channel smart dimmer. It can control by wall switch button, wireless remoter, also work with ethernet or RS485 port, open protocol for development by other software. 8 channel output DC0-10V, you can connect with LED driver to LED light or LED strip. The LED driver’s power according to…
8 channel dimmer
8-Channel Smart Dimmer – KC868-D8
KC868-D8 smart dimmer controller support HTTP, MQTT for home assistant. Solution A: KC868-D8 dimmer controller work with DC12V or DC24V LED strip by Power Driver Solution B: KC868-D8 dimmer controller work with AC220V or AC110V lamp by analog SSR 1. What switch panel or buttons can be used? KC868-D8 input ports (K1+ — K8+) and…
kbox
KBOX iOS app update for touch mode
“KBOX” iOS phone app updated, we have added new function: 1. update add controller mode, support add KC868-H2/H4/H8/H16/H32 2. add “TOUCH” mode for every relay switch output that can auto OFF when you pressed button.
