esp32 relay board
32 channel 4G ESP32 relay board – A32 Pro
KinCony A32 Pro ESP32 relay board based on ESP32-S3-WROOM-1U (N16R8) wifi chip, it have 32 manual control switch buttons can turn ON/OFF relay even if system is broken. Support 32 channel relay output and 2 channel dc 0-10v dimmer output, 2 channel 1-wire GPIOs, 4 channel analog input ports. It support 4G module (SIM7600 series)…
esp32 sd card
ESP32 SD card module – ATF
We have designed ESP32 SD card module – ATF. it can record data save file to SD card. It need you write arduino code. for example, you can receiver serial data write LOG file to SD card. You can read digital input sensor or temperature humidity sensor write to SD card. it’s easy integrate to…
Raspberry Pi iot gateway
KinCony Server16 Raspberry Pi IoT gateway released
KinCony Server16 is a Raspberry Pi iot gateway for smart home automation and industrial automation control, It have 16 channel relay, many digital input ports with optocoupler isolation. The most important is integrated Raspberry pi CM4 module. CM4 manage relay, digital input ports, PWM, RF 433M reciever, IR receiver, SIM7600 4G module directly, easy use…
ESP32 Tuya IoT adapter
KinCony ESP32 Tuya IoT Adapter V2 released
KinCony ESP32 Tuya IoT adapter V2 let relay board or IoT devices easy integrate to tuya IoT platform. We have designed by ESP32 work with Tuya module. Tuya module will connect with Tuya cloud server, when using tuya phone app, message will send to tuya wifi module and decode by ESP32. ESP32 support use arduino…
ESP32 Tuya AC dimmer module
ESP32 AC dimmer module – ADR
We have designed mini ESP32 AC dimmer module – ADR. it can use for lamp change brightness or change fan motor speed. it’s easy integrate to home assistant by ESPHome. ADR design for home automation DIYer. The hardware use by ESP32-WROOM-32E + Tuya wifi module, so that can use home assistant in local network OR…
i2c io expander
i2c io expander input board – DI8
KinCony DI8 is PCF8574 IO Expansion i2c relay board. extend 8 channel digital input port (with optocoupler isolation circuit).  digital input support use by dry contact signal. 8 LEDs show INPUT state on PCB.  A0,A1,A2 PCF8574 i2c address can set by DIP switch. DI8 support install on DIN RAIL. it’s open source board. here is…
pcf8574 relay board
PCF8574 io expansion i2c relay board – KinCony DO8 released
KinCony DO8 is PCF8574 IO Expansion i2c relay board. extend 8 channel 10A relay. manual control buttons on board can control relay ON/OFF directly without any software. manual control buttons control relay’s coin physically. A0,A1,A2 PCF8574 i2c address can set by DIP switch. DO8 support install on DIN RAIL. it’s open source board. here is…
pcf8574 relay board
PCF8574 IO Expansion i2c relay board -DO8
ESP32 energy monitor
30 Channel ESP32 energy monitor – KinCony M30 released
We have designed 30 Channel ESP32 energy monitor open source board – M30 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation DIYer. The hardware have 30CH CT Clamp sensor INPUT ports + 3CH ZMPT101B voltage sensor + SD card + 30CH RGB colorful LED for current value. Ethernet+RS485+4G modbus 30CH high-accuracy energy meter…
30 Channel ESP32 energy monitor board – M30
