socket debugger
KC868-Hx controller TCP Server&Client Debugger released
We have written a new development and debug software tool for KC868-Hx smart relay controller. There are two test versions available: 1.TCP Server Version tool: Debugger download: KC868Hx-Debug-Server (use in Local LAN) Source code download: KC868-Hx Debug-Server local LAN control demo source code.rar (C++Builder 10.2.3) 2.TCP Client Version tool: Debugger download: KC868Hx-Debug-Client (use in Local…
smart home software
KC868 Smart Network Controller PC Software Icos update
We have add the new icos for many electrical equipment. You can download the package and put all to your KC868 Smart Controller PC software install directory, then setting in the PC software options. If there is no icon you want in the icon library, you can contact us and we will design and update…
faq
KC868 Smart Home Automation Module FAQ
KC868 Smart Home Automation Module FAQ: 1. Can multiple controller be used in the same mobile app? Yes, multiple controllers of different models can be added to a mobile account.   2. Can controller’s input port trigger output port? You can create a scene, define the actions at the output, and then associate it with…
kc868-h32lw
32 CHANNEL WIFI RELAY MODULE – KC868-H32LW
We improved ethernet relay module — KC868-H32. The new model called “KC868-H32L”. What’s the difference between “KC868-H32” and “KC868-H32L”? 1: Relay Max load from 5A to 10A. 2:Use pluggable terminals,easy to install and maintain. 3:The function of power-off memory of relay switch is added. If the power is cut off suddenly or power failure, the…
kc868-h32l
32 CHANNEL ETHERNET RELAY MODULE – KC868-H32L
32-Channel-relay-controller
ethernet relay module KC868-H32L released
