How to set wifi of kc868-g
how to set wifi ssid and password of KC868-G smart home hub, it can control device by phone app for send zigbee , RF315MHz,RF433MHz, IR signal. ?
every KC868 smart controller only can add to one phone app account, if you need to add to another app account, you must delete the controller in your app account firstly. Then another phone account can add the controller. If you want to some people control one controller. You can authorize the controller to other…
every KC868 controller can only add to one phone app account, if some body want to control one controller. the master account can authorize sub-account to share equipment control. ?
how to create scenes for relay ON or OFF. Such as all relay ON, all relay OFF, or relay1 ON, relay2 OFF, relay 3 ON by one button on phone APP. for example , you can set a scene: relay 1 ON , delay 2 seconds, relay 1 OFF. …. any actions you needed can…
How to set timer with scene: such as 8:00 AM to do scene (ALL relay OFF), or 06:00 PM to do scene (ALL relay ON). You can set scene run time on phone app.
16 Channel Digital input,16 Channel Analog input,5 Channel Temperature,99 Channel Power Meter.
32 channel power box control by phone APP and computer software or voice control by Google home or Amazon alexa speaker.
Products Parameter: Dimension: 108x117x40mm Working Voltage: DC 12V Material:Fire resistance ABS、metal shell Working Temp: -20℃~70℃ Working Humidity: 20%RH ~ 80%RH Output Load:each 250V/10A Communication mode:Ethernet/RS232 Input port qty:8 ports Output port qty:16 ports The following information introduces KC868-H8 controller. KC868-H4, KC868-H2, KC868-H8, KC868-H32 Smart Home Automation controller are KC868 series of KinCony’s products,…
