Wifi IP Camera Waterproof Outdoor
Use KC868-H8 / KC868-H32 controller to remote control relay while watch ipcameras. It support 1-4 CCTV.
Use KC868-H8 / KC868-H32 Smart Controller to remote control relay while watch ipcameras.
Model size of smart home building: 60cmx60cmx50cm(LxWxH) Demonstration function of Smart Building model: 1. Individual control of light in each room 2. Electric Garage Door Control 3. Electric curtain control 4. Infrared Counterfire Alarm 5. Television control (4.3 inch display) 6. Video surveillance (switchable TV screen) 7. Air conditioning control 8. Outdoor Landscape Light Control…
You can use amazon Echo Plus control socket directly. Our plug is standard ZigBee3.0 protocol. Also can used by philips hue hub. The control demo can see our video link: https://www.kincony.com/zigbee-3-0-smart-plug-voice-control-by-echo-plus.html
You can use amazon Echo Plus voice control socket directly. Our plug is standard ZigBee3.0 protocol. Also can used by philips hue hub.
program code by yourself that can control ZigBee device , such as light, dimmer, curtain, IR by socket port, the gateway not need internet.
Why KC868 is a super controller? It can: Control by phone APP (iOS & Android) PC remote(WAN-internet) or local(LAN-no internet) control Voice Control by Amazon Alexa & APP (Need voice module) Voice Control by Google Home Assistant & APP (Need voice module) Manual Control by keyboard & panel switch Control by RS232, Open source,…
KC868-Hx Local Control by PC software via USB-RS232. First install the USB-RS232 adapter driver. Then search the COM number, set in the software.
Firstly, config the WiFi work mode in “UPD” that in WAN, then change to “TCP Server” that in LAN. Note: After changing the parameters, the power should be restarted.
How to config wifi with KC868-H8W KC868-H32W smart home ip relay controller
