wall touch switch of ZigBee
KinCony wall touch switch of ZigBee wireless smart home solution of KC868 smart home system Video demonstrates ZigBee switch manual control, app control, dual switch panel control of one lamp
How to configure mobile app and alarm function demonstration. Connect the sensor to kc868-h8 controller via wires to trigger alarm demonstration.
Home security Pir Sensor Alarm Detector work with KC868 controller. How to configure mobile app and alarm function demonstration. Connect the sensor to kc868-h8 controller via wires to trigger alarm demonstration.
Uair temperature and humidity development board shell install. There are interface of temperature sensor, humidity sensor and PM2.5 sensor on the PCB board (PM2.5 sensor is not standard, pls buy if required). You can install it directly on PCB board, temperature and humidity sensor is recommended to install for extension to ensure numerical accuracy.…
The development board of air quality detection module (U-air hardware PCB) can upload the data collected by the sensors of temperature, humidity and PM2.5 to the server via GRPS. Clients can view the data through web page or APP.
Smoke Detector Sensor Product parameters: Operating voltage: 12v/DC~24v/DC Static current: ≤ 2MA Alarm current: ≤ 10MA Operating temperature: -10 ℃ ~ 50 ℃ Operating humidity: ≤ 95%RH Alarm mode: Networked output / Led indication Alarm Detection area: 20㎡ Sensitivity level: Level 1 Alarm output: Relay output (N/O or N/C optional) Product size: φ 104*51mm
PIR Sensor Product Parameter Sensor Type: Imported high sensitive sensor Operating Voltage: 9v/DC~24v/DC Product Category: Wired wide Angle Installation: Wall hanging or Angle installation Detection Angle: 110 ° Operating temperature:-10 ℃ ~ 50 ℃ Environmental humidity: 5%~95%RH Product size: 89*52.5*38.5mm
Magnetic door sensor Product Parameters” Dimension:106*38*10mm 106*16*16mm 106*50*50mm Induction Distance: 50-70mm Switch Form:N/C, N/O and Converted Electrical Parameter: Max power 10W, Max Voltage 100V, Max Current 0.5A Material: Zinc Alloy, silver gray Lead Wire:1007UL#22AWG 550mm 380mm SS steel protective pipe Package: 1set/bag, 50sets/CTN, 18.0kg/CTN Suitable: Rolling shutter door
Gas detector sensor product parameter: Sensor: New nanometer technology sensor, long service life Induced Gas: Coal gas, natural gas, liquefied petroleum gas Alarm concentration: Coal gas 0.1~0.5%、natural gas 0.1~0.3%、liquefied petroleum gas 0.1~0.5% Operating Current: < 100MA Operating Temperature: -10 ℃ ~ 55 ℃ Operating Humidity: < 97%RH Alarm Volume: 75 decibels at 10 feet Response Time: <…
