esp32 K-Type thermocouple
esp32 K-Type thermocouple 24CH relay module – A24 released
KinCony A24 esp32 board based on ESP32 wifi chip, it have manual control switch buttons can turn ON/OFF relay even if system is broken. Support 3CH K-Type thermocouple use by MAX31855 chip. It support GSM module for SMS, voice call, GPRS communication for Tuya mobile application. Use SMS or call to turn ON/OFF relay will…
rs485 io module
RS485 io module – KC868-HAv2 released
The smallest RS485 IO Module — KC868-HAv2 module. size 3cm*3cm. let your switch panel and dry contact sensor convert to RS485. KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome, easy integrate to home assistant. You can add everyone KC868-HA board with 6 digital input ports and 6 digital output ports to home assistant by RS485.
rs485 io module
RS485 IO Module – KC868-HAv2
The smallest RS485 IO Module — KC868-HAv2 module. size 3cm*3cm. let your switch panel and dry contact sensor convert to RS485. KC868-HA RS485 INPUT & OUTPUT plugin for ESPHome, easy integrate to home assistant. You can add everyone KC868-HA board with 6 digital input ports and 6 digital output ports to home assistant by RS485.…
ESP32 Energy Meter
ESP32 Energy Meter Relay Controller – KinCony M1 released
We have designed ESP32 Energy Meter Relay Controller – KinCony M1 (ESP32 1 channel AC voltage and current energy monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. it use by BL0942 energy chip, support by ESPHome. the hardware have BL0942 sensor + 1CH DIGITAL INPUT port + 1CH ZMPT107-1…
