iot ESP32 power meter
KC868-M16v2 iot ESP32 power meter board released
We have designed KC868-M16v2 new version (ESP32 16 Channel CT Clamp Energy Monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH CT Clamp sensor INPUT ports + 3CH ZMPT101B voltage sensor + SHT30 temperature & humidity sensor + Ethernet POE+ WiFi + Bluetooth + DS3231 RTC…
iot ESP32 power meter – KC868-M16v2
esp32
“KCS” v2 firmware for KC868-A series (ESP32) board released
“KCS” means “KinCony Super” , V2 version have added many new functions, support local IFTTT on board, 4G SIM7600 module for remote control without internet, you can use by SMS, voice call or 4G tuya app. It has powerful functions and supports multiple communication protocols. “KCS” support home assistant, Tuya app. Support HTTP, MQTT, TCP,…
esp32 diy pcb
KC868-1U ESP32 DIY PCB Board released
KC868-1U is a esp32 diy pcb board use for esp32 diy project. it can install to 1U size box, let your relay controller become smart. if you have a power sequencer, KC868-1U will easy connect it, so that smart control your rack power strip. You can DIY one smart power sequencer. It will support arduino…
esp32 diy pcb
ESP32 DIY PCB Board – KC868-1U
KC868-1U is a esp32 diy pcb board. it can install to 1U size box, let your relay controller become smart. if you have a power sequencer, KC868-1U will easy connect it, so that smart control your rack power strip. You can DIY one smart power sequencer. It will support arduino IDE, home assistant by ESPHome,…
raspberry pi 4 relay board
KinCony Server-Mini Raspberry Pi4 relay board released
KinCony Server-Mini is a raspberry pi CM4 relay board for smart home automation and industrial automation control, it’s mini version of KC868-Server. Server-Mini smart controller support 8 channel relay output and wall switch connect to it directly. The most important is integrated Raspberry pi CM4 module. Relay and digital input port have connected with CM4…
