esp32 diy pcb
KC868-1U ESP32 DIY PCB Board released
KC868-1U is a esp32 diy pcb board use for esp32 diy project. it can install to 1U size box, let your relay controller become smart. if you have a power sequencer, KC868-1U will easy connect it, so that smart control your rack power strip. You can DIY one smart power sequencer. It will support arduino…
esp32 diy pcb
ESP32 DIY PCB Board – KC868-1U
KC868-1U is a esp32 diy pcb board. it can install to 1U size box, let your relay controller become smart. if you have a power sequencer, KC868-1U will easy connect it, so that smart control your rack power strip. You can DIY one smart power sequencer. It will support arduino IDE, home assistant by ESPHome,…
raspberry pi 4 relay board
KinCony Server-Mini Raspberry Pi4 relay board released
KinCony Server-Mini is a raspberry pi CM4 relay board for smart home automation and industrial automation control, it’s mini version of KC868-Server. Server-Mini smart controller support 8 channel relay output and wall switch connect to it directly. The most important is integrated Raspberry pi CM4 module. Relay and digital input port have connected with CM4…
Raspberry Pi distribution panel
Raspberry Pi distribution panel (Home assistant+CM4) released
We have designed new 16CH Raspberry Pi distribution panel, it’s very powerful Linux Computer, made by Raspberry Pi CM4, it have 16 channel relay output, 16 digital input ports, ethernet + ESP32 module, work with internet or without internet. support home assistant app, Google home app, Amazon alexa app, Apple homekit app, set by Node-Red.…
ct clamp energy monitor
16 Channel CT Clamp Energy Monitor
We have designed KC868-M16 (ESP32 16 Channel CT Clamp Energy Monitor) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 16CH CT Clamp sensor INPUT ports + 3CH analog input + Ethernet + WiFi + Bluetooth + DS3231 RTC module + SSD1306 I2C LCD display + SD card.
kc868-a32m
KC868-A32M ESP32 32 Channel MOSFET Board Released
We have designed KC868-A32M (ESP32 MOSFET Module) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 32CH MOSFET output + 4CH analog input + RS485 + Ethernet + WiFi + Bluetooth + 4G SIM7600 or 2G SIM800L GSM module + DS3231 RTC module + RF433MHz Receiver. We let…
esp32 can bus
KC868-A8M ESP32 8 Channel CAN Bus Board Released
We have designed KC868-A8M (ESP32 CAN Bus Board) for home automation DIYer. it can easy integrate to home assistant by ESPHome. the hardware have 8CH MOSFET output + 8CH digital input + 4CH analog input, support CAN Bus + RS485 + Ethernet + WiFi + Bluetooth + 4G SIM7600 or 2G SIM800L GSM module +…
