smart-distribution-panel
Smart distribution system (Tuya+Alexa+Google+HomeKit) released
We have designed new 32CH smart distribution system, it’s very powerful, it have 32 channel relay output, 6 digital input ports, ethernet + Tuya WiFi + ESP32 module, work with internet or without internet. support Tuya app, home assistant app, Google home app, Amazon alexa app, Apple homekit app, KinCony smart home app and KinCony…
esp32 sd card
KC868-ASR ESP32 SD card sensor RTC record board Released
KC868-ASR ESP32 SD card sensor record board based on ESP32 chip. It have many hardware resource for you to use. It have two channel relay, two GPIOs for temperature or humidity sensors. one SD card socket and DS3231 high quality RTC chip. It’s very easy for home automation DIY. You can write any code by…
kc868-a4s
KC868-A4S 4G esp32 arduino relay board Released
KC868-A4S esp32 arduino board based on ESP32 wifi chip, many hardware resource for you to use. it support GSM module for SMS, voice call, GPRS communication. Use SMS or call to turn ON/OFF relay will be very easy for home automation DIY. It also have 8 channel dimmer output and PWM output extender. You can…
kcs
“KCS” firmware for KC868-A series (ESP32) board released
“KCS” means “KinCony Super” , this is a new firmware developed by KinCony for KC868-A series products in 2023. we have released firmware for KC868-A4, KC868-A6, KC868-A8, KC868-A8S, KC868-A16, KC868-E16S, KC868-A32, KC868-A64, KC868-A128, KC868-AK, KC868-AI. We will continue to update firmware according to user feedback. Input configuration:
esp32
how to use “KCS” firmware for KinCony ESP32 board
Note: This document use for KinCony smart controller: KC868-A4 A6 A8 A8S A16 E16S A32 A64 A128 if you want to read by PDF file, download user guide PDF file. 1. Download “KCS” firmware to KinCony KC868-A series board. a. Download “ESP32 download tool” from https://www.kincony.com/wp-content/uploads/2022/08/flash_download_tool_3.9.2.zip and firmware BIN file from KinCony forum. b. Open “flash_download_tool_3.9.2.exe”,…
kcs
“KCS” new firmware for KC868-Ax under developing
“KCS” means “KinCony Super” , this is a new firmware developed by KinCony for KC868-A series products in 2023. It has powerful functions and supports multiple communication protocols. It can manage various functions of the device through web pages, such as: input configuration, output configuration, monitoring management page, Timing schedule task mode, network configuration, communication…
esp32 tuya adapter
KC868-ATC Tuya Convert ESP32
Ovdje sam naišao na tajanstveni proizvod pod nazivom “ESP32 Tuya IoT adapter”, možete cijeniti originalnost njegovog izgleda s gornje fotografije. S druge strane, ime sadrži ESP32, a kao što znate, ako uređaj sadrži ESP32, onda je to nesumnjivo sjajna stvar, pa sam odlučio istražiti njegov uređaj. Pa, Tuya me također zaintrigirao, bilo je zanimljivo pridružiti se…
esp32 tuya adapter
KC868-ATC Tuya adapter hardware design details
Here we came across a product called “ESP32 Tuya IoT adapter”, you can appreciate the originality of its appearance from the photo above. On the other hand, the name contains ESP32, and as you know, if the device contains ESP32, then this is undoubtedly a great thing, so I decided to explore its device. Well, Tuya…
kc868-ai
KC868-AI: 48 digitalnih ulaza + ESP32, ETH, RS232, RS485 i IR i prijemnici od 433 MHz
Dok smo se bavili prijašnjim Kincony kontrolerima, pokušavajući ih primjeniti u pametnim projektima, Kincony također nije gubio vrijeme i objavio je još nekoliko kontrolera koji će na naše zadovoljstvo naći primjenu u mnogobrojnim projektima prikupljanja i obrade podataka. Ovaj put je to kontroler Kincony KC868-AI prvenstveno namjenjen za organiziranje prikupljanja podataka iz mnogobrojnih ulaza (48…
