- KC868-COL cooperates with the KC868-Hx relay controller to work as an automatic control system. KC868-COL is the AI brain and KC868-Hx is the actuator. KC868-COL uses the IFTTT command locally without the Internet.
- Watch all sensors data on PC in real-time and do automatic control as a user preset.
- Like a PLC controller, but it not need professional technology to program, it’s easy to use.
- It has 16 digital input, 16 analog input, and 5 temperature DS18B20 sensors.
- Support multiple control modes: A: relay ON, OFF, and status switch; B: send custom command by RS232 custom command auto control with third-party equipment
- Automatic control all runs locally without the Internet, no need cloud server. Protect user data privacy.
- Support many kinds of sensors, such as temperature, humidity, pressure, light, pH value, water level, soil temperature, and humidity, ammonia, noise, air quality, human infrared, smoke, gas, door magnetic, etc.
- Users can create MAX 50 automatic control command save to KC868-COL.
