KinCony B16M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 16 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B16M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B16M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY.
Model No. KinCony B16M
Description: KinCony 16 Channel ESP32-S3 Smart Controller – B16M
Power supply: 12-24V DC
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
16CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
software solution:
1. download firmware by ESPHome, integrate to home assistant or use by web service.
2. download tasmota firmware.
3. write your own arudino code for your own requirements.
Related technical information
ESP32 I/O pin define: https://www.kincony.com/forum/showthread.php?tid=6781
config yaml file for ESPHome: https://www.kincony.com/forum/showthread.php?tid=6782
arduino demo source code: https://www.kincony.com/forum/forumdisplay.php?fid=61
Different views of the B16M:
Here are the hardware design details:
B16M support install on DIN RAIL
As a standard size, it looks like it is installed in a distribution box.
