KinCony ESP32 Tuya IoT adapter let relay board or IoT devices easy integrate to tuya IoT platform. We have designed by ESP32 work with Tuya module. Tuya module will connect with Tuya cloud server, when using tuya phone app, message will send to tuya wifi module and decode by ESP32. ESP32 support use arduino IDE to write code, get the tuya message and send any command to RS232 or RS485 or network device. it’s a good convert tool for smart home automation DIY.
adapter support to use “Tuya MCU SDK Arduino Library”
KC868-H32B,KC868-H32BS …. HxB series smart controller will be easy support TUYA phone application, alexa and google home voice control function.
it support install on the DIN rail.
you can write any arduino IDE code or by IDF tool to write code and download firmware by USB-C cable.
install wifi antena by SMA socket.
Tuya app , alexa app and google home / google assistant app will be support.
suspport use tuya phone app, google home and alexa echo speaker
KinCony esp32 tuya adapter work with KC868-H32B by RS232 port
KinCony esp32 tuya adapter work with KC868-H32BS by RS232 port
KinCony esp32 tuya adapter work with KC868-H32BS by RS485 port running MODBUS protocol
KinCony esp32 tuya adapter work with KC868-Server by RS232 port
Related technical information
schematic: https://www.kincony.com/download/KinCony-TUYA_ESP32_Adapter.pdf
arduino firmware source code: https://www.kincony.com/forum/forumdisplay.php?fid=32
