We improved ethernet relay module — KC868-H32. The new model called “KC868-H32L”. What’s the difference between “KC868-H32” and “KC868-H32L”?
1: Relay Max load from 5A to 10A.
2:Use pluggable terminals,easy to install and maintain.
3:The function of power-off memory of relay switch is added. If the power is cut off suddenly or power failure, the relay will automatically return to the state before the power cut when the power is called again.
